Friction Modifier or no? Amsoil
Gunfighter
P.J.
West Michigan
2021 Jeep Wrangler High Altitude
Trying not to get warning points
Good morning,
I have the Amsoil pictured below - on the website it says:
Jeep Wrangler JL Friction Modifier or no? Amsoil 1706967289336
but on the bottle it says:
Jeep Wrangler JL Friction Modifier or no? Amsoil 1706967217682
I have the LSD in the rear. Thoughts/experience?
Jeep Wrangler JL Friction Modifier or no? Amsoil Amsoil 1
Jeep Wrangler JL Friction Modifier or no? Amsoil Amsoil 2
Ormond Beach, Florida
Retired at 55 ..
I myself won't talk anything Amsoil.
I encourage you to read through this whole thread before buying gear oil. You need to make the right decision on gear oil weight and more..
Oh ...... do yourself a favor and buy gear oil in squeezable pouches.
azwjowner
Phoenix
Drive in tight circles and see if you hear chattering from the differential. Odds are you won’t because of the friction modifier already In the oil. If you do hear chatter, add the Slip Lock in small amounts until the chatter is gone.
The real problem, and @CarbonSteel will no doubt be along shortly to point this out, is most of us would run 75w140 in the rear per Dana‘s recommendation and for the increased heat that these axles generate. But 75w90 is adequate (do you really want to be only adequate?).
Amsoil makes excellent gear oils. I’m about to put in their Severe Gear 75w140.
Bulletbill
Tom
Central PA
2021 JLUR
Jeep Wrangler JL Friction Modifier or no? Amsoil 1706967805674
This is a blurb from mopars diff fluid. I would guess it works the same way for the Amsoil fluid. To be certain I would contact Amsoil.
Jeep Wrangler JL Friction Modifier or no? Amsoil 1706968005526
CarbonSteel
Good morning,
Nearly all synthetic gear oil has friction modifier in it (including Amsoil as you have noted) and rarely for an OEM LSD axle is additional friction modifier needed.
Drive in a slow figure eight pattern in a parking lot and listen for popping sounds after refilling the axle. If that type noise is experienced then additional FM is needed.
You will want to add in VERY small amounts because too much FM will cause the LSD to perform as an open axle. Again, I do not think that you will need it.
If you tow or run heavier loads, use 75W-140 (I would run it regardless as Dana specifies it).
Gunfighter
Gunfighter
P.J.
West Michigan
Perfect - thank you and to all the others who took time to post about my question.
Also, The 75W-90 will go in the front/the 75W-140 for the rear.
Retired at 55 ..
Yup, ..... 75W-140 in both front and rear diffs as Dana specifies this.
Jtphoto
Thunder Bay ON
Interestingly I have run 75-90 in all my Jeeps and trucks for the last 45 years with no issues, but then I live in the north where it seldom gets to 100f in the summer but does go down to -40. Even the 5.38 gears I ran in my 08 for well over 150,000klm as my daily on 37s had no issues with 75-90.
so, you do what works for you but the most important thing is that the oil be changed regularly, especially with LSD that tends to accumulate clutch material in the oil over time.
Gunfighter
Gunfighter
P.J.
West Michigan
Thanks for sharing. I also believe the 75W-90 will be fine from yours and others experience. I had my 2006 F-250 (4:30 gears) for 15 years with 127k miles w/o issue using the stuff. I did get some 75W-140 for the JL's rear simply because we enjoy zooming around Silver Lake Sand Dunes (April can't come soon enough).
azwjowner
Phoenix
Yes, but the JL has a reduced oil capacity compared to the JK and all of those previous axles, and runs even hotter.
DaltonGang
Doesn't Play Well With Others
Oh no, not another Amsoil thread.
I think we need a counter that registers how long this Forum goes without anyone speaking that word.
Pig-Pen
Banned Camp
2018 JLU
jabroni
an accident sign with numbers that change?
It has been 0 days since Amsoil has been mentioned.
Jeep Wrangler JL Friction Modifier or no? Amsoil IMG_0924
Gunfighter
Gunfighter
P.J.
West Michigan
Yeah, Just asked a question about friction modifier and.....well....folks have to get all critical about something. Pretty comical how a thread goes in a direction not intended. Didn't know folks get their panties in a wad over "Amsoil". ?? That's the internet for ya.
AlgUSF
Melbourne, FL
2021 JLUS, 2014 Tundra, 2013 Odyssey, 2002 Civic
Where can I find this magic elixir that is AMSOIL? I can't find it at my local NAPA or Wally Mart. If only they had some sort of network of sales people or something.... :-(
