Frequent diff fluid changes
jlandry287
2022 JLUR Diesel
I’ve got 45,xxx miles on my ecodiesel. I’ve changed the fluid in the differentials 2x already, it smelled burnt both times.
I’m running 37s with stock gears and use amsoil for the changes. Front gets 75w-90 and the rear gets 75w-140 since I do occasionally tow.
I’ve had the rear locker position sensor replaced under warranty, it failed driving from Louisiana to Washington while hauling my ATV.
Occasionally when I’m towing the sensor will start to act up, showing the rear locker is engaged but it’s not. After letting the jeep sit for a while, this error goes away.
Anybody have any clue why I’m burning through diff fluid, or am I just overthinking it?
Kracka
Christopher
Oak Point, TX
C8 Corvette, 19 KL Trailhawk Elite, 23 JL Rubicon
37's and the ...W-140 runs too hot. Step it down to 75W-110 and add an aluminum rear differential cover.
I run Amsoil SG 75W-85 in my Grand Cherokee and have had zero issues towing at max capacity.
We have the aFe cast aluminum cover on the JL and have been all over the country without issue; run Redline 75W-85 in it.
UTME
T
2024 Rubicon-X Unlimited
That’s weird. Just replaced front and rear for the first time. Currently have 42,000 miles. Everything looked good.
Jeep Wrangler JL Frequent diff fluid changes IMG_4768
Jeep Wrangler JL Frequent diff fluid changes IMG_4772
Jeep Wrangler JL Frequent diff fluid changes IMG_4771
flick2614
Randy
AZ
2021 Jeep JLU Rubicon Diesel
It seems to me that towing and rear lockers are often a combo that creates a ton of heat and causes issues, not isolated to just Jeep. Full sizes see it too but there are a million options for housings that increase the volume of oil and provide some cooling in the form of finned covers in the full-size category. I haven’t seen any covers for the JL that advertise increased capacity. If there are any out there that may be the solution.
Kracka
Christopher
Oak Point, TX
Jeep Wrangler JL Frequent diff fluid changes PXL_20231128_003714456
Jeep Wrangler JL Frequent diff fluid changes PXL_20231128_003627110
jlandry287
jlandry287
2022 JLUR Diesel
i'd guess running stock gears with 37s puts more strain on the gears than if you'd re-geared to match the 37s.
It's an ecodiesel so I personally think the gearing is fine (could be wrong) and others that run a similar setup are not reporting the same issue.
jlandry287
jlandry287
2022 JLUR Diesel
also worth mentioning I'm running aftermarket diff covers in the front and rear
Jeep Wrangler JL Frequent diff fluid changes 1754430324804-3g
zouch
Berkeley, CA
XJ, JLUWD
sorry if my point wasn't clear enough; we're not talking about gear ratios being suitable (or not). the point is the gears are under more pressure now that you've put larger tires on it.
your comment here made me think "so what is he doing different?", which you answered in your next post.
i'm always suspicious of the oil flow in most aftermarket diff covers.
Badunit
VA
1997 TJ, 2023 JT
Interesting video on diff covers. It is a Banks marketing video but probably truthful. Mostly it is about flat backed ones. The one you posted a picture isn't one of those but still an interesting video.
WillysMeow
Corruptifornia
Bought my first new Jerp! :)
Bit wrassler
Wow, great video on diff covers and oiling, thanks!
