Factory height differences
rizion
Caleb
Houston
Wrangler JL 2dr Sport S
If a Rubicon JL is an inch taller than a Sport and you install the same complete suspension lift of say 3", wouldn't the Rubi and Sport be the same height after if each got the same work done? Springs, shocks, control arms and track bar. I'm assuming all parts are the same dimensions aside from the springs and shocks from the factory. If that isn't the case, then obviously my first question is already answered.
azwjowner
Phoenix
Yes, they would be the same height. (Assuming same tires too, which you didn't mention). The springs control the height.
JustDave
Kersey
2021 Jeep Wrangler
I put a 2 inch mopar lift on my Sport & it raised it about 3 inches. I was told it would raise a Rubicon 2 but others will get 3-4. Not sure if that means anything concerning your post, but there it is.
jbcrane
40.5853° N, 105.0844° W
Just a Jeep, M'am.
3D Animation
So a Rubicon with the 2" Mopar lift is ultimately the same height as a Sahara/Sport/Willys with the same 2" Mopar lift, assuming they have the same tires.
rcadden
Ricky
Asheville, NC
Marketing
If you install the 2" MOPAR lift on a Sport and a Rubicon (assuming otherwise identical vehicles, plastic bumpers, same wheels/tires/etc), two things will be true:
1. The Sport will gain closer to 3"+ of height, while the Rubicon will only get ~2"
2. The Sport and Rubicon will both be the same height
The *change* in height will be different, since they have different starting heights. But the *final height* should be identical.
rizion
rizion
Caleb
Houston
Yep. Forgot to mention wheels/tires but assuming the same there as well
rizion
rizion
Caleb
Houston
That is where I was confusing myself. The net change is different but resulting height is the same. Thanks all for clarifying. Not sure why I was hung up on this but I am no longer.
rizion
rizion
Caleb
Houston
I also just learned the Rubicon fender flares are like 2” taller than Sports which would make the Rubi seem taller even if not. I need some of those….
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
Thank you!!!! I was going to post the same thing, because I've seen these threads go pages of responses that just confuse the issue, when ultimately people are getting hung up on the change from starting point.
Pinky Tuscadero
Kenosha Wi
2021 Pink RHD Wrangler 2015 RHD Wrangler
Just slightly shy of 4" with the 2" Mopar lift on our RHD
Love it ? and warranty covered now for 100k/ 8yrs all around
6.2Blazer
Ohio
2019 JL Sport
Just as said above. The other thing that can cause confusion (and mentioned in another post) is that the Rubicon flares are different and cut higher. If you install the same lift springs on a Rubicon and Sport, and using the same tires, the Rubicon will have a higher reading if you measure to the wheel wells/flares.
rizion
rizion
Caleb
Houston
I didn't realize how much of an impact those fender flares have. I NEED them...
LiVinIt
Larry
Vero Beach, Fl
2022 JLU Sport S
I went to a dealership recently after closing and measured the front fender height and width difference on a Rubicon using a level and tape measure. I came up with approx 1.5” taller and .75” wider, if this helps anyone.
I’m buying a set of takeoff fenders and wanted to know what the difference was going to be.
rizion
rizion
Caleb
Houston
that is a noticeable difference for sure.
danm
Philadelphia
2020 Jeep Wrangler Rubicon 2-Door Sting Gray
