F upped my steering knuckle
jellis4148
Missouri
To start I've noticed some issues, but couldn't tell what they were. My Camber should off on alignment rack, and I added sleeves. The Jeep drove fine, but I could never get the steering wheel straight. Today I put it on the lift and holy crap. It looks like the ball joint is bad, and thanks to the guys at Dynatrac for sending me a rebuild kit, but if you zoom in on the video and look at the lower portion of the ball joint under the knuckle you can see the play in it. I was going to do iron knuckles, but don't really have the funds for both. Hopefully my extended warranty covers it.
kah.mun.rah
Merenkahre Jr.
Duat
Do you think the aluminum hole has wallowed out?
jellis4148
jellis4148
Missouri
Absolutely. It has to be. My cost for a new knuckle is $625 from Mopar of the junk Aluminum. I should be able to get it covered under my extended warranty. Don't really want to spend $900 for Reid's right now even though I know this will happen again.
jellis4148
jellis4148
Missouri
I don't know if the ball joint is bad or not. It looks like it is. Talked to Dynatrac and they are awesome. They are sending me a rebuild kit for the one ball joint. Cory was great to talk to.
Jmos4
2020 Challenger Scat Pack M6/2007 Ram 2500 G56
Hi,
Believe the knuckles from a Gladiator are iron, might be marginal cheaper than the AL ones.
Regards,
Pig-Pen
Banned Camp
2018 JLU
jabroni
Hi,
Regards,
i thought that was just the Mojave. which are available from Mopar for about $500 each.
if you can get them replaced under warranty go for it. it will happen again though at some point.
otherwise go Reid/Mopar.
@SadRobot just had Reids and dynatrac installed. then the shop informed her that now she needs something else for the Reids. something to do with steering? he said you dont need it with the Mopars.
Vatdevil
Rob
Mars, PA
2022 Rubicon 2 Door 6 Speed
Mojave has the iron knuckles. I Found a good price on a used set. Look around
jellis4148
jellis4148
Missouri
I tried to get the cast iron knuckles this morning. They are on a 45+ day backorder according to parts. Remember that I work at a CDJR store. I was fortunate and the warranty was approved. Also, my cost on the iron knuckles was $625. I pay wholesale cost.
SadRobot
Los Angeles
2025 Prius LE
u thought that was just the Mojave. which are available from Mopar for about $500 each.
Yeah I guess now I need RCVS because with the Reids they have a different turn angle and could cause my u-joints to snap?
I guess I'll test that theory out in Texas in a few weeks.
Adv_aw8s
Rob
2021 Rubicon diesel
I purchased some used knuckles off this forum from a 392 and swapped them out with my aluminum ones on my JLURD. I also install dynatrac ball joints at the same time.
Jeep Wrangler JL F upped my steering knuckle PXL_20240525_230039384
azjl#3
North AZ
jellis4148
jellis4148
Missouri
As far as I know that’s a big fat nope on the Regular Rubicon. I mean heaven forbid someone actually taking there Rubicon off-road.
