External mount of Maxtrax?
258_T18A
2024 Rubicon 392, 1979 CJ7
Looking for some ideas here. I don't have a roof rack, and I have a 392 with the camera in the rear tire so tire mount is out.
Was thinking maybe something like this and then mount the boards to the Hi-Lift?
https://www.skidmark4x4.com/
258_T18A
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
Here is another expensive option. I just went this route not knowing I had to buy an extra adapter plate and mounting pins. TrailRax.com
Jeep Wrangler JL External mount of Maxtrax? IMG_5436
Jeepeto
Josh
North Texas
2021 JLUR XR
Sparky
American Adventure Lab Spare Tire Platform has a solution, it isn’t cheap but it’s nice to have extra storage as well
I like the TrailRax @dragoneggs mentioned but based on my barely being able to clear my rear doors with the rotopax on, I don’t think you could mount maxtrax on them and still open the rear doors on a 4 door. Just a heads up if you’ve got a 4 door and are considering this route, make sure you confirm compatibility.
Jeep Wrangler JL External mount of Maxtrax? IMG_0747
Jeep Wrangler JL External mount of Maxtrax? IMG_6268
Jeep Wrangler JL External mount of Maxtrax? IMG_4697
Jeep Wrangler JL External mount of Maxtrax? AA709233
dpike
New Jersey
'20 JLUR 3.6
There's the other spare tire ratchet strap rack company that's a fraction of the cost of that max trax rack .. rock slide maybe ?... Something like that... I don't remember the name but someone here will and you can fab up a bracket for traction boards for a few bucks with parts from Home Depot.
Jeepeto
Josh
North Texas
2021 JLUR XR
Sparky
Ooh, good point. I had a set of the rock slide engineering EZ racks on my last rig. It would require a bracket for sure, and if you could use both mount points from the EZ rack it should be pretty secure ?
Jeep Wrangler JL External mount of Maxtrax? Moab Summer 2K21-2
Jeep Wrangler JL External mount of Maxtrax? E8E86F08-8667-4B6E-AFD1-236B176FE9E0
RicRecon
Ric
NorCal
2021 JLUR 3.0, 2021 JT Overland 3.0
Are those Milwaukee boxes on your cargo shelf? Seem to fit well. Are they mounted so they don’t bounce around?
Terrymo
Terry
2023 JLURXR 3.6 ET
I have that hitch skid and I’m not sure how practical it would be to have a hilift and Maxtrax hanging off the back of the Jeep In that spot. Or maybe I’m not understanding what youre describing?
Jeep Wrangler JL External mount of Maxtrax? IMG_0589
Jeepeto
Josh
North Texas
2021 JLUR XR
Sparky
Yeah, the packout stuff is great, they are on the AAL packout mounts, they fit perfectly back there.
258_T18A
Yeah, at first I was thinking of mounting them directly to the hi-lift which mounts to the top lip, but doesn't look like there's much space there. I noticed there are also holes in the side that faces back, maybe could rig a couple of pieces of flat stock steel to that and then bolt the boards to those?
Terrymo
Terry
2023 JLURXR 3.6 ET
IDK here’s a rear pic. If your idea still allows the tailgate to open and doesn’t ruin your departure angle…maybe.
Jeep Wrangler JL External mount of Maxtrax? IMG_0596
