Engine air filter - how often to replace?
Gangplank
Vero Beach, FL
2021 JLU Willys 3.6 eTorque w/ Mopar lift. 2022 JLU Rubicon 2.0T still stock
Per manual engine air filter change interval is every 3 hrs or 30k miles.
Paluss
maryland
2022 JLURD
as others has stated, its very easy to change yourself, depends on were you live and drive, 25k is what I did and it wasn't really dirty, I changed the cabin filter too, and it was quite dirty.....
Aonar
N.W. Iowa
2012 Rubi and Snazzy 2021 JLURD
I live (and tend to wheel) in a very dusty environ. At the 1st video below, you can see how dirty my factory filter got at less than 10K. (In the static pic below that, you can see how dirty the new filter got after a trip).
I switched out to cleanable, DRY filters. I now have 2 of them. This lets me swap out after a long dusty trip, so I have a clean filter for the hundreds of miles trip back home.
In the last vid you can see how easy it is to change the filters yourself.
Jeep Wrangler JL Engine air filter - how often to replace? 1681993539143
At the following link you can see how easy it is to change.
Merc
Carlos
South Pasadena
2021 2 door 6mt Willys; 2013 Subaru Crosstrek
This is at 20k.
Jeep Wrangler JL Engine air filter - how often to replace? IMG_3223
speedymart
mephis
2021 jl
Replace every 30k per the factory schedule unless you drive in incredibly dusty conditions. Then replace it every 10k along with the cabin filter.
Heimkehr
Pennsylvania
2021 JLU 2.0T
FWIW, Blackstone Labs has made specific mention of effective [engine] air filtration contributing to the excellent numbers on the used oil analysis reports that I've curated for the Jeep, and other vehicles that I've owned. Thus my policy of using OEM air filters and adhering to the mileage-based replacement intervals noted in the Owner's Manuals.
Anecdotally, our Honda Pilot started misfiring at 60k on the original air filter. It actually went into limp mode because of this.
As others said, it will depend on your use but 16k is early.
Sounds like my cabin filter. AC fan couldn't push air through it. 🤣
