ECODIESEL DIFF RE-GEARING
drick
AZ
2016 JKUR & 2021 JLURD
sales monkey
That's what I would go with. I'm at 45k miles with 4.56's. I would do it again in a heartbeat. We live at altitude in Colorado and tow an off-road trailer quit frequently.
thanks for confirming
zouch
Berkeley, CA
XJ, JLUWD
it pulls uphill at whatever speed i set, and rolls out of the pull as the load decreases; whatever it needs to do to maintain speed. nothing unusual; just what it's supposed to do. (i don't remember my Quattro being much different.)
How does yours behave when climbing / cresting hills?
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Interesting. I noticed it a lot more when driving home last night loaded down with people. Definitely had to cut it off at the crest of hills to keep it from "launching".
drick
AZ
sales monkey
FWIW - this happens to me all the time, not just when loaded
ALeeL
Anthony
2021 JLURD
cruise control for me is fine on the flats, on hills it bangs all over through the gears and significantly over revs the engine vs. what is needed.
this behavior coupled with the overheating problems is a recipe for disaster
Same here. Without cruise control, I can go up just about anything in 8th. The exact same hills and speed on cruise control will cause it to slow down one to two mph going up the hill, then downshift a gear or two to compensate for the cruise control letting the Jeep loose speed. This happens even with my 50hp/100 lb-ft tune, and has nothing to do with power, but rather how the CC was programed.
Most Jeep diesel owners I spoke with about this, who have never had diesels, generally don't notice since they are used to this with gas engines and don't see an issue. However, most that have owned diesels before and are used to their diesels not having to downshift on such a low grade are the ones that are very annoyed by it.
I just put in manual mode in 8th gear while on cruise control past 55 mph. Last trip to Moab, it took every mountain like this aside from a very long and steep one that required downshifting to 7th at 2,100 rpm. That same mountain had my buddy, who was following me in his 3.6L 8-speed, downshift to 4th screaming at 4,600 rpm.
zouch
Berkeley, CA
XJ, JLUWD
interesting indeed!
looks like we all 4 have similar build dates, so that should eliminate some amount of variable. (mine is Oct '20.)
i think John and i are running similar tire/gear setups. i think Drick hasn't regeared yet, so that's a little off, and Anthonys re-tune definitely throws in a wild card.
i know my old XJ had a box where we could adjust the rate of attack and how hard it would accelerate when in Cruise; i wonder if there's an equivalent function of that same sort of thing in our JLs,..? (probably somewhere in software, knowing the way these things are these days.)
our Mercedes turbodiesel was pretty good on cruise too, even with significantly less torque available. i always just thought this JL thing did such a nice job on Cruise because it was also a turbodiesel.
i don't fret about it downshifting; it's got 8 gears to use to keep it at whatever it thinks its 'optimum' is as opposed to the 3 and 4 speeds we grew up with, and is likely to split those loads into smaller slices.
the 8HP75 does such a nice job moving through gears it's a non-issue.
ALeeL
Anthony
2021 JLURD
My BMW diesel has the same ZF 8-speed except it is an 8HP55 instead of a 8HP75. The shifting on that thing is significantly better than my Jeep, even when not in cruise control. I think that if I never had my BMW, then I would not complain about the Jeeps 8-speed as much. I have just never felt like I am in the wrong gear at times like I have with the Jeep.
In cruise control, it does not wait to load up the engine until you are two mph below your set speed like the Jeep does. Using my Torque app on both to see commanded engine load and actual engine load, the BMW starts commanding engine load the second the speed drops from your set speed to keep you within that speed and hardly ever requires a downshift. The Jeep waits until you dropped two mph, then loads up the engine causing the torque converter to slip, forcing an unneeded downshift with often too much power shooting you over your set speed. This is especially frustrating in the Texas hill country where you are going up and down hills and it is constantly shifting when it does not need to.
The other way the BMW 8HP is programmed better is that it has sport/tow haul mode as well as regular auto and manual mode. With the Jeep, moving the shifter to the left puts it in manual mode. With the BMW, moving the shifter to the left puts it in sports/tow haul mode which still shifts automatically, but holds gears longer to keep you in slightly higher rpms than stock for more power. Moving the shifter up or down while in sport/tow haul mode will then put it in manual mode where you can shift manually if you wanted. I was shocked that it did not do this when I got my Jeep since it can clearly be done.
Most of the time, I manually shift my Jeep because I prefer manuals and the Jeep shift points are horrible for a diesel. It feels like Jeep just slapped the same shift programming on the diesels as what was used on the gasers and called it a day. Like I said, I probably would not complain as much about if I did not have my BMW to feel what the 8HP is really capable of, even in their heavy SUV variants.
zouch
Berkeley, CA
XJ, JLUWD
since you mention it, the 8HP45 6HP in our E93 did a very nice job, even with the gas engine and no turbo.
cruise worked fine there too.
EDIT:
corrected typo in transmission spec
ALeeL
Anthony
2021 JLURD
The years of the BMW E-chassis like my old E90 335d diesel did not have an 8-speed 8HP transmission. They had the 6-speed transmissions that was either a ZF 6HP or a transmission made by General Motors.
zouch
Berkeley, CA
XJ, JLUWD
you're right; typo on my part. our E93 was indeed a 6-speed transmission.
BAKNBLK
Nevada
JT diesel
My A6 TDI had the ZF 8HP55A and shifted fine, my JTD shifts fine also no complaints at all.
drick
AZ
sales monkey
interesting indeed!
can you remind me where i can find my build date zouch? i ordered in Dec of 2020 as i recall.
fwiw - rig is going in next week to get the 4.56's in
Ratbert
PNW
Software Engineer
Your door jam tells you month and year. Month and date is on your window sticker.
Jeep Wrangler JL ECODIESEL DIFF RE-GEARING 1971
