EcoD Fuel Filter Change
Jteakus
Oil City Louisiana
2020 Ecodiesel Unlimited Rubicon
Even though Jeep says we can go 20K miles between changes I wanted to take a look.
Jteakus
Jteakus
Oil City Louisiana
Filter is under this little skid. I also drain the water separator every time I rotate tires which is about every 3,300 miles
Jteakus
Jteakus
Oil City Louisiana
Pull 3 10mm bolts, pull skid, drain separator then remove housing with 28mm socket. It’s tight but not Toyota tight
Jteakus
Jteakus
Oil City Louisiana
I hooked the old filter with a 90 degree screwdriver to pull it loose
Jteakus
Jteakus
Oil City Louisiana
This is what mine looked like at 15,660 miles
Jteakus
Jteakus
Oil City Louisiana
Change o-ring and lube it with clean oil
Jteakus
Jteakus
Oil City Louisiana
Make sure you line up the 2 slots with the ones in the housing, push it up, screw separator cap back on and snug it.
Jeep Wrangler JL EcoD Fuel Filter Change E2535F42-FD40-48A9-9CFF-0A5F6D2760AD
Jeep Wrangler JL EcoD Fuel Filter Change 3DB3450A-637B-4F2F-B622-7CB4F738A93C
Jteakus
Jteakus
Oil City Louisiana
I keep a vacuum cap over water drain to keep funk out
Jteakus
Jteakus
Oil City Louisiana
Before I reinstalled skid I cycled pump 3 times then started it up and checked for leaks. This is the filter I used.
just trying to help someone if they haven’t changed filter yet.
rickinAZ
Phoenix
NaĂŻve question from a first-timer:
So when I loosen/remove the filter is there any "drainage" that needs to be captured to avoid a mess? In other words, do I need a catch basin, or is this a dry operation?
Jteakus
Jteakus
Oil City Louisiana
Need a catch pan. Before you unscrew filter housing drain water separator valve till no more diesel comes out
Jteakus
Jteakus
Oil City Louisiana
Punch the start button twice without your foot on the brake pedal. You’ll hear the pump run for about 20 seconds then it will stop. Push start button to turn power off then repeat. I could hear pump changing tone the third time so I was sure it had built pressure. Then I put my foot on brake and started it, fired right up.
Capricorn
Las Vegas, NV
2024 JL Willys XR V6
Network Architect & Engineer
Since there is a hole or opening by the water fuel separator valve on the cover, can the water be drained without removing the cover?
Jteakus
Jteakus
Oil City Louisiana
I think you are supposed to be able to but every time I tried I got aggravated and just pulled the skid/cover
