EcoD Fuel Filter Change
Jteakus
Oil City Louisiana
2020 Ecodiesel Unlimited Rubicon
Even though Jeep says we can go 20K miles between changes I wanted to take a look.
Jteakus
Jteakus
Oil City Louisiana
Filter is under this little skid. I also drain the water separator every time I rotate tires which is about every 3,300 miles
Jeep Wrangler JL EcoD Fuel Filter Change C046D4FC-3123-401B-950A-D76786B7A761
Jeep Wrangler JL EcoD Fuel Filter Change 7560B5DC-C4C3-4606-8235-D89813A77A69
Jteakus
Jteakus
Oil City Louisiana
Pull 3 10mm bolts, pull skid, drain separator then remove housing with 28mm socket. It’s tight but not Toyota tight
Jeep Wrangler JL EcoD Fuel Filter Change B09F041C-C6CF-43FE-8488-EFDAD12ED4FC
Jeep Wrangler JL EcoD Fuel Filter Change 170A81A8-1E66-4C58-9597-A7D33D9DB335
Jteakus
Jteakus
Oil City Louisiana
I hooked the old filter with a 90 degree screwdriver to pull it loose
Jeep Wrangler JL EcoD Fuel Filter Change BCD2E371-8CB7-46C2-9BD5-CF2CE236298F
Jeep Wrangler JL EcoD Fuel Filter Change 2D405ADF-8DBE-41F0-82A8-46202F203CCE
Jteakus
Jteakus
Oil City Louisiana
This is what mine looked like at 15,660 miles
Jeep Wrangler JL EcoD Fuel Filter Change DFC079C7-0B4D-4354-AA43-A001A051AD25
Jeep Wrangler JL EcoD Fuel Filter Change EF9D1B2F-AE70-4F5E-BDE3-DE9A75C581ED
Jteakus
Jteakus
Oil City Louisiana
Change o-ring and lube it with clean oil
Jeep Wrangler JL EcoD Fuel Filter Change 17F1C6EF-1974-4EFD-A83A-3966AA6C18D8
Jeep Wrangler JL EcoD Fuel Filter Change C5CB3399-E89A-454F-A9CD-E17FCFA5909B
Jteakus
Jteakus
Oil City Louisiana
Make sure you line up the 2 slots with the ones in the housing, push it up, screw separator cap back on and snug it.
Jeep Wrangler JL EcoD Fuel Filter Change E2535F42-FD40-48A9-9CFF-0A5F6D2760AD
Jeep Wrangler JL EcoD Fuel Filter Change 3DB3450A-637B-4F2F-B622-7CB4F738A93C
Jteakus
Jteakus
Oil City Louisiana
I keep a vacuum cap over water drain to keep funk out
Jeep Wrangler JL EcoD Fuel Filter Change EFE7F5D1-8AF8-45AB-8CF3-75C4603B9AE8
Jeep Wrangler JL EcoD Fuel Filter Change B85FAC66-5C7A-4009-A8D3-F7D90AEE4A07
Jteakus
Jteakus
Oil City Louisiana
Before I reinstalled skid I cycled pump 3 times then started it up and checked for leaks. This is the filter I used.
just trying to help someone if they haven’t changed filter yet.
Jeep Wrangler JL EcoD Fuel Filter Change 9D4DC7BD-3336-4D90-A90F-710FF7749635
rickinAZ
Phoenix
2026 MOAB 392
NaĂŻve question from a first-timer:
So when I loosen/remove the filter is there any "drainage" that needs to be captured to avoid a mess? In other words, do I need a catch basin, or is this a dry operation?
Jteakus
Jteakus
Oil City Louisiana
Need a catch pan. Before you unscrew filter housing drain water separator valve till no more diesel comes out
Jteakus
Jteakus
Oil City Louisiana
Punch the start button twice without your foot on the brake pedal. You’ll hear the pump run for about 20 seconds then it will stop. Push start button to turn power off then repeat. I could hear pump changing tone the third time so I was sure it had built pressure. Then I put my foot on brake and started it, fired right up.
Capricorn
Las Vegas, NV
2024 JL Willys XR V6
Network Architect & Engineer
Since there is a hole or opening by the water fuel separator valve on the cover, can the water be drained without removing the cover?
Jteakus
Jteakus
Oil City Louisiana
I think you are supposed to be able to but every time I tried I got aggravated and just pulled the skid/cover
