alphawolff
- Jul 31, 2023
- california
- 2021 JLU
if you repeated that verbatim then that gentlemen is spouting complete bullshitGoing to for at least documentation purposes hopefully they can find it and fix it just dropped it off at the dealer and he said that his battery monitor module issue which could be caused by something like a ground wire
The way he described it is all these different modules go into a central campus so it conceivable if I had a loose ground wire in the auxiliary switch panel for like aftermarket lights that would disrupt the signal to the battery monitor module, and we would not be covered on the warranty
Which I suppose I can understand
How often does the battery monitor a module go bad and would a previous dead battery cause this?
