Check engine light
Ripsaw502
Millersport, Ohio
2018 WRANGLER UNLIMITED RUBICON 4X4
Dump truck Driver
Recently when starting My 2018 Jeep Rubicon unlimited The check engine light will come on and the ABS, swaybar control, traction control, service shifter, service parking break, and all these lights come on and It will not shift out of park. Turn the vehicle off and turn it back on and itstill won't come out of park. 3rd times a charm will shift out of park In to drive. The Jeep has been Back-and-forth to John Henderer Chrysler Jeep Dodge In Heath Ohio multiple times for similar issues but this is the most recent. They clear the codes and will work for a short time but still not solving the issue. I believe water is getting into the electrical system somewhere but they have neither the time or the resources to fix it correctly. Has anyone else had these problems or is there a star report similar to this?
WhereRU_A-A-Ron
Aaron
Arkansas
2021 JLU Willys, 2023 Ford Expedition Stealth Edition, 1968 Mustang Coupe 289
Business Director
Are you still on original batteries?
Old Dogger
Bill
Cave Creek Arizona
Check all of your fuses, and make sure that they are in tight. If yes, then it is probably battery related.
Ripsaw502
Ripsaw502
Millersport, Ohio
Dump truck Driver
here are the codes sorry it took so long had to pull teeth to get them
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Should be an easy enough diag if the issue is repeatable. Unplug unnecessary modules and drive it. Then unplug necessary modules and run it in limp mode. shake some wiring harnesses around until it acts up or doesn't. A day or two worth of work.
