Does the JL shift knob come off?
toothirtyj
Indy, IN
'21 Hellayella JL Willys, 3.6L/6MT, 4.10's
LE
Posted below are my SpeedDawg adapters with their Hellayella TC and MT knobs. I took a second to sand off the red paint on the reverse lockout and it looks great in my opinion.
SpeedDawg and B&M have installation instructions on their websites for removal of old knobs and installation of new ones.
Jeep Wrangler JL Does the JL shift knob come off? PXL_20211022_164158172
Jeep Wrangler JL Does the JL shift knob come off? PXL_20211022_192238857
Jeep Wrangler JL Does the JL shift knob come off? PXL_20211226_182035035
m3reno
Sal
caldwell
2022 Jeep Wrangler JLU
I purchased an adapter from Amazon for non threaded shafts and then purchased a leather shifter similar in size to the Original shifter but not as wide. I have to say it shifts much smoother. It sit's slightly higher but is actually more comfortable.
ALRUI
Arnold
Murphy, NC
2018 JLU Sahara, 2003 F150 S-Crew FX4, Others
Do you have a link for the adapter by chance?
Thanks!
Maverick909
I.E.
I just ordered the ABD shifter with the jeep willys logo. Will see how it goes. jsut the long lead time to get it paint matched but i dont mind. Ill probably forget i ordered it next month and it will show up LOL
ALRUI
Arnold
Murphy, NC
Let us know how you like it long with some pics:)
Maverick909
I.E.
JKJLCamp
Morton, IL
2022 JL 3.6L M6, 2015 JKU Sahara 3.6L M6
Working on a shift knob project now using an adapter that matches the stepped shift knob profile so there is zero movement and doesn't increase the height like adapters do. Machining the first sample piece this week hopefully. Put a few weeks on the printed version and I prefer this so much to having the shift knob stick up 2" higher with an adapter.
Still retained with set screws, but in a more proper fashion. The factory knob has a V-groove where the OEM snap ring clips into. Using cone point set screws they will center into this V-groove and have the same or better retention than factory (can't just pull it off).
More details to come later!
Jeep Wrangler JL Does the JL shift knob come off? IMG_7126
Jeep Wrangler JL Does the JL shift knob come off? IMG_7112
ALRUI
Arnold
Murphy, NC
You got a lot further then I did:) Looks good. Did consider trying to incorporate the clip into the design at all?
m3reno
Sal
caldwell
Do you need space for the reverse lock out to work? I just received my speed dawg adapter which keeps it's it at the original height.
JKJLCamp
Morton, IL
Thanks! Considered briefly, but since my goal was to have a much closer, tighter fit to the stock shifter than the other products the cone-point set screws will be far simpler to implement.
JKJLCamp
Morton, IL
That adapter definitely raises the height of the shift knob, a lot. That was one of the things I disliked about it the most. That, and the exposed set screws that dig into your hand while shifting because of the thin wall material that is tapped.
Jeep Wrangler JL Does the JL shift knob come off? IMG_7100
m3reno
Sal
caldwell
I have a tap and die set that's coming Saturday and then I can complete this project. It's either going to look great!!....or a complete bust. I'll post pics when I'm done
