Do you really need beadlocks?
lashlee
Knoxville, TN
'18 JLUR 2.0 Turbo 4 (Sold), Tesla M3P
If I were to do it all over again, I would've bought beadlocks. We wheel out at Windrock here in Tennessee, and headed to Moab on the 10th of next month. I usually air down to 14-15 psi when we wheel and haven't had an issue yet with Raceline wheels and 37" KM3's.
zouch
Berkeley, CA
XJ, JLUWD
the devil is in the detail.
DOT does not "Approve" wheels. they set a standard to which manufacturers are to comply if they want to produce a "Compliant" wheel.
as for J**p or Icon marketing? this is just another example of how it's as reliable as anything else written by a marketeer.
if you're concerned about the legality, it's the Motor Vehicle Codes where you're operating that matter. if you find a place where the Vehicle Codes specifically outlaw BeadLocks, please share for the benefit of all.
Below is the description of the factory Jeep bead lock capable wheels that come on the 329 [sic] and XR equipped Jeeps. [NOTE: the beadlock wheels were available long before those pkgs.]
<much snippage>
So exactly which vehicle components are require to be DOT approved?
Icon has a beadlock wheel setup that is DOT approved and can be road operated.
J392
NORCAL
2023 JLU 392, 18 Charger Hellcat, 21 DSRT, 14 Ram
C-36 Contractor
Debating whether or not to get them (KMCs) on my JLUR, are they worth the hassle and cost or no? How common is it for low psi tires to slip off a non beadlock rim?
(Use will be casual offroading, medium difficulty trails)
I just had my Beadlocks delivered. Going to mount the tires and take the wheels in for balancing. For me it's insurance, somthing I will no longer need to worry about. If you wheel a lot then I would recommend it.
Jeep Wrangler JL Do you really need beadlocks? 20230226_152742
Cycle11111
Alastair
Truckee CA
2019 2 Door Wrangler Sport
I have the ICON Rebound PROs and they provide much the same benefit as pure beadlocks and ARE DOT compliant/legal. I air down to around 12 PSI when off road and have had two friends knock off a bead when out wheeling. One was at night after a very long day and was a huge hassle to deal with - he has since gone to true beadlocks. I did not want a none DOT wheel and is why I jumped on the ICONs.
Also pure beadlocks are heavier
SH556JL
Steven
Florida/Georgia
21 JLR M6 RIP, 23 JLR M6
There are absolutely DOT approved beadlocks.
Notwithstanding, have you ever heard of anyone get specifically pulled over for beadlocks?
Lastly, they suck to manitain regardless and unless you're required to air down to like 5psi regularly, they're a huge pain in the ass and not worth the hassle. Somewhat like wearing a cosplay costume full time. ;)
Cosplay can be fun, just saying.
With that said, I'm good with a simulated bead lock or rash ring, AKA beauty ring.
bacon392
Northern NJ
Sarge Rubicon 392 XR
In practical terms, I don’t think the DOT approval is so much about legality as it is about liability. Should you get into an accident with beadlocks on, you can bet that your or the other party’s insurance company will find a way to bring that into the picture and deny coverage. It’s like towing over your limits, it’s probably fine to tow slightly over the rated limit of the vehicle, but you’re on your own if you have an accident.
Certainly beadlocks on the road are not a safety concern. If installed correctly they’re safer than non-beadlocks.
Old Jeeper
Don
US Army Infantry, IT Engineer
Just a word to the wise. Bead locks are not approved by the DOT for On Road use.
You are correct, they are NOT approved for on road use!
Contents
Not complying with SAE J2530 standard for wheels
Society of Automotive Engineers (SAE) has a J2530 guideline to set performance requirements and other procedures for aftermarket wheels on passenger cars and pickup trucks.
They do not comply with the recommendations due to their unsafe design. They also don’t pass the safety tests mentioned in the J2530 standard.
Therefore, manufacturers do not offer such wheels for use in city areas or highways with more traffic. IT makes them liable for any accident that occurs in such situations.
If you install them while driving on public roads, law enforcement personnel can stop you and write you a fix-it ticket.
There is a lot more here: https://trucksauthority.com/why-are-beadlocks-not-street-legal/
You got it RIGHT?
Here is my take: I ran BLs for over 8 years, never had an issue of any kind. I ran them with GY MTRs and BFG KM2s, 37 x 12:50 x 17. Offroad PSI 3-5 PSI, on road with my BFG KM2s I ran 16-18 in town and 18-20 on the Hwy.
Over the time frame that I ran on my TJR I was driving in states from Texas to Cali and Utah to Mexico and I racked up almost 100k miles and never an issue
Are they for everyone. NO! If you buy them 'cause they are Kool' you will regret it. You better know how to maintain them and if you do not know the procedure to torque down 32-36 bolts on the BL Ring you are running a risk that could result in catastrophic results on or off-road.
I ran Grade 8 bolts and replaced them annually. Think: $$$
If you are not running the Big Boy trails 7+ I would not bother.
FYI, 8 yrs/100k miles across the SW and never stopped by any LEO.
donmontalvo
Don
Livingston, TX
donmontalvo.com
2021 Jeep Wrangler Unlimited Rubicon (Snazzberry)
XtremeRetard
Richard
Rocky Mountains
JLURXR
My experience from many miles in both beadlocks and non beadlocks on 8 rated trails.
Non beadlocks good down for me down to 12psi no problem and yes on 8 rated trails. Never dropped a bead on sandstone which is where I run mostly.
So quick answer, is you DO NOT NEED THEM.
Beadlocks good to whatever pressure. But for me below 8 PSI means the sidewall now presses hard against the rim when crawling rocks. 37s on 17s in JLU.
Main benefit of super low PSI is super soft ride on rough stuff, plus Im sure some more grip. But my happy number is now closer to 9 PSI for a little more sidewall support over sharp rocks. IMO while you may get some more grip with less pressure due to more tire wrap over stuff, its not night and day on normal road tires.
So in summary, really I think they are only good if you are hardcore and want any advantage you can get, plus more peace of mind. Oh they are better for use in sand when the less pressure you run the better... Run normal rims until you "know" you need to get beadlocks IMO.
BeauSabreur
Frankenmuth, MI
2018 JL 2-Door Rubicon
Great analogy!
I’ll echo some of the others here: OP, for your intended use case, I’d say they’re absolutely NOT worth the cost.
I considered bead lock wheels. Ultimately, I chose Method Race Wheels. I’ve used them on rocky Colorado mountain passes (Imogene, Black Bear)…15psi. And, on Michigan sand dunes..8psi. Perform flawlessly.
