DIY Spacer Lift
Rssazn
Virginia
Wrangler JLU, Grand Cherokee L, BMW M5
Looking to do a 1.5-2" spacer lift and deciding what's the easiest/quickest method. I've done these on trucks before, but I assume if I just compress the springs while its on its own weight, jack up the jeep, it should be a simple pull out, place the spacer, and reinsert yeah? Or do I have to go through the 50 steps I keep seeing videos on youtube?
richk225
Rich
New Jersey
2021 392Rubicon XR 2017 Jeep Grand Cherokee
retired due to broken back
Good questio. With the suspension at full droop I wonder if you can compress the springs(with a good spring compressor or rented one) enough to slide them on?Maybe there’s some tips like just having to remove the lower control arm bolts at the axle. Did you talk to the manufacturer?
jac04
CT
2021 Mojave / 2014 JKRX
The way you describe will work to get the spacer in, but because of the change in ride height, the rubber suspension bushings will be partially 'bound' at normal ride height. Therefore, you need to loosen all of the control arm, track bar & shock bolts so that the rubber bushings re-establish their neutral position at ride height, then re-tighten all the bolts. It's the right way to do the job.
rcadden
Ricky
Asheville, NC
Marketing
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
There's a big jounce tube in the middle of the front springs that the spacer has to slide up around.
roaniecowpony
Retired Engineer
Seems like the easiest way is to put the frame on stands, remove the wheels, disconnect the shocks with a jack under the axle, then let it drop down until you can remove the spring.
Rssazn
Virginia
guess i'll just take it on base garage shop and borrow their tools.
Camaroboi13
Justin
San Bernardino, CA
2022 JTOD, 2024 JLU W
LEO... life in Chino
It’s crazy how easy it is, don’t be intimidated by it.
Jack up vehicle and support the frame with stands.
Remove wheels and tires
Support the axle with a jack
Disconnect lower shock bolts
Disconnect sway bar end links
Lower the axle and pull the springs out
Add spacers and reinstall springs
Jack the axle back into place
Attach end links and shock bolts
Install wheels and remove Jack stands.
enjoy.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
If you're going to over complicate things with spring compressors and trying to do one corner at a time, you will make the job far more difficult than it has to be.
jac04
CT
enjoy.
This is missing the steps of loosening all of the control arm and track bar bolts, and then re-tightening them with the vehicle back on the ground with the suspension at the re-established ride height.
Camaroboi13
Justin
San Bernardino, CA
Not necessary on a spacer lift. I’ve done several and haven’t done that on any 1-2” lift.
GATORB8
CLT NC
Not required for install, but it's still a good idea so you seat the bushing back at neutral at the new ride height.
GATORB8
CLT NC
jac04
CT
It's the only correct way to do the job.
