Discreet air compressor install - 4xe
unknownsolo
Washington, USA
22 Wrangler Rubicon 4XE
Can you see it?
Jeep Wrangler JL Discreet air compressor install - 4xe IMG_0890
Disclaimer: I got the idea from here: https://www.jlwranglerforums.com/forum/threads/arb-single-compressor-mounting-options.12647/
I wanted onboard air but did not want it in the cabin or under the seat. I already have an amp and a CB mounted under my seats. We also cannot mount it under the hood by the driver wheel in the 4xe, so Grimm mount is not an option. After a lot of research and giving up on mounting a dual ARB air compressor, I settled for the single one because it is smaller, lighter, and easier to handle. I stumbled upon the forum post above and wanted to try the same.
The process was very straightforward. The mount that comes in the box is like it was made to be mounted behind the taillight. The taillight clears without any issues, too.
1- take the air compressor mount apart.
2- Mount behind the taillight.
3- Put the air compressor back on.
4- Wire to the battery or aux switch (I ran mine to aux 2).
5- Run the hose coupling anywhere in that area (I ran mine up by the hard top harness port cover - pics below).
6- Admire your work.
It sounds easier said than done, mainly because it is a very tight space, and a lot of patience is needed. That said, I would do it all over again. I can't think of putting anything else in that space, and mounting the air compressor there clears up more room in the cabin for other stuff. It is also very easy to get access back to it for maintenance.
The air compressor is well protected. It is not in the cabin but is also not exposed. I did not run the air intake up like in the post above. I did not find a reason for that. The taillight area is open to the wheel well and is already very well-ventilated.
Jeep Wrangler JL Discreet air compressor install - 4xe IMG_0855
Jeep Wrangler JL Discreet air compressor install - 4xe IMG_0854
Jeep Wrangler JL Discreet air compressor install - 4xe IMG_0858
Jeep Wrangler JL Discreet air compressor install - 4xe IMG_0880
Jeep Wrangler JL Discreet air compressor install - 4xe IMG_0885
Jeep Wrangler JL Discreet air compressor install - 4xe IMG_0886
Jeep Wrangler JL Discreet air compressor install - 4xe IMG_0888
Jeep Wrangler JL Discreet air compressor install - 4xe IMG_0889
Jeep Wrangler JL Discreet air compressor install - 4xe IMG_0906
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Awesome work! This will be on my list once I finish the trailer and have time to work on the Jeep again.
Thanks for taking the time to share a full write up!
Bulletbill
Tom
Central PA
2021 JLUR
Awesome mod, very clean and professional looking. Has anyone tried this with any other pumps? I have a smittybilt and would be curious if anyone thinks mounting it in the same spot would be possible.
WhatExit?
The 48th State
2020 JT Rubicon Launch Edition | 2021 F350 6.7L
Love the stealth install! If only I could do this on my Gladiator
jinxxxxx
eddie
Jeep Wrangler JL Sport S
Love the installation. Where did you pull power from ?
unknownsolo
unknownsolo
Washington, USA
Thank you. Got power from aux connections under the hood. You can drop the cables down, fish them through the body all the way to the front, take the cables back up to the aux switches, and enjoy. That was actually the easiest part of this whole install.
The hardest part was working on the mount because there isn't a lot of space.
jinxxxxx
eddie
Thanks. That will work because I did get the aux switches. Any problems with heat or noise ? Or is it too soon to tell?
The Fixer
North Jersey
2018 Mojito! JLS, 2018 Firecracker JLUSS
Teacher
Very slick! I love the fact that it doesn't use any space at all on the inside.
unknownsolo
unknownsolo
Washington, USA
I live in WA, it doesn't get too hot here, so I am not sure, but I can't imagine it being any worse than under the hood. If you look behind your taillight, that area is actually open to the wheel well and is ventilated, I doubt it will overheat in there.
redracer
Robert
Manteca, CA
2023 4xe Rubicon
I'm so doing this on my 4xe. I had an ARB single mounted to the firewall with the ACM mount on my '18 JLUR and have been looking for a good place on my 4xe since I bought it in November. The spot that I was going to use is in the under floor tub... but this is better!
unknownsolo
unknownsolo
Washington, USA
I thought about the cargo tub, too, but I have my tools there, and I wanted the air compressor out of the way, and completely hidden somewhere. This has been working for me really well. Solid build you even forget it's there, and you don't need any additional mount hardware.
One advise is prep prep prep. It's easy and the install is straight forward but is very time consuming due to the limited space. It took me like an hour and a half to tighten two bolts. It's smooth sailing afterwards once you get the hang of it. Mounting was the most time-consuming part. Wiring to the aux switches was the easiest part (at least for me).
Once I had everything mounted, I decided to add rubber washers to help dampen the noise, so I had to undo the mount. That alone took all afternoon.
redracer
Robert
Manteca, CA
2023 4xe Rubicon
do you have any pictures showing how you bolted the mounting plate down?
