Differential Fluid
JDLouisville
Louisville KY
‘23 Jeep Wrangler Rubicon 392 XR
Someone above asked about fluid volume in F&R Diffs.
JL Wranger Differential capacity:
186 FBI - Front Axle 1.82 Pints 80w-90
210 FBI - Front Axle 2.18 Pints
200 RBI - Rear Axle 2.43 Pints 80w-90, if towing 75w-140
220 RBI - Rear Axle w/ EDL 3.06 Pints
220 RBI - Rear Axle w/ T/L 3.02 Pints
186 FBI (Model 30) - Front Axle
MOPAR Gear & Axle Lubricant (SAE 80W-90) (API GL-5)
1.82 Pints/0.86 Liters
210 FBI (Model 44) - Front Axle
2.18 Pints/1.03 Liters
200 RBI (Model 44) - Rear Axle
MOPAR Gear & Axle Lubricant (SAE 80W-90) (API GL-5) or equivalent.
For trailer towing, use MOPAR Synthetic Gear & Axle Lubricant (SAE 75W-140).
Models equipped with Trac-Lok require an additive.
2.43 Pints/1.15 Liters
220 RBI (Model 44) Rear Axle – EDL
3.06 Pints/1.45 Liters
220 RBI (Model 44) Rear Axle – T/L
3.02 Pints/1.43 Liters
BLACKMOAB
2018 Black JLU MOAB, 2021 Black Lexus GX 460
How do you determine which model of differentials your JLU has? It doesn't indicate which you have on the window sticker. Mine just says Trac Lok differential rear axle.
INCRHULK
Lance
Canada
litwphoto.com
2019 Wrangler Unlimited Sahara (retired), 2021 Gladiator Rubicon Diesel
Program Manager, Information Technology
Trac Lok is the rear 220 with LSD. 80-90 and friction additive. EDIT: unless you have the tow package. 75w-140 and additive.
Rufus
NYC
2018 2 door JL Sport 3.6 V6
I always use VALVOLINE 75W-140 SYNTHETIC for all my jeep differentials--
It was recommended for my '08 JKUR and that's what i use in my JL-
W.E.
JIMBO
If you don’t add an FM with the Valvoline have you noticed any chattering?
JIMBOX
JAMES
FERNLEY NV
RETIRED
Nope, I've used the 75w-140 for years and It's labelled LIMITED SLIP--
Works great, very quiet !
Good luck
JIMBO
Rufus
NYC
Good luck
JIMBO
Thanks! I ordered 2L!
PyrPatriot
Kentucky
Jeep Gladiator
So not wanting to spend $150 to replace differential fluid for both axles (need slightly 5.25pts, so need to buy 3qts to get the needed 2.625pts), what SAE 75W85 API GL-5 Gear and Axle Oil/Lubricant is good?
I was looking at the Red Line 50105 75W85 GL-5 Gear Oil, $60 for 1gal, but the label states it is for hypoid limited slip diffs, and my Sport has open diffs.
Will that work or is there an alternative I should use?
Here is the list of fluids from my dealership's part department, provided to me when I gave them my VIN.
Jeep Wrangler JL Differential Fluid 1614618629765
The Mopar stuff is over $50/qt. Even online after shipping 3qts is about $120. I am ok with $60-70 per gal for alternative stuff, the concern is the "for hypoid limited slip differentials" on the Red Line bottle, which on their website expands to "Contains additional friction modifiers for suitability with clutch-type limited slip differentials - for most LSDs, no additional friction modifiers are required " My JT has open diffs, don't need the friction modifier, I am concerned this one having the friction addative would harm something.
