Death Wobble
Mr. Tahiti
Ken
2021 JL 2-Door
My experience with death wobble.
Fairly new 21 2dr - got progressively worse and was able to re-create, dealer replaced steering stabilizer and symptom vanished. A while later (maybe six months) a milder version of symptom returned, dealer replaced with updated SS and symptom vanished again. I have since lifted Jeep (1.5 JKS) and replaced SS with a Fox - death wobble has not returned and hopefully never will.
The death wobble experience was scarier than any of the trails I have been on.
gek
Code Monkey
Yup, should replace the band aid every so often or you run the risk of infection.
shagles
Skylar
2020 JLU Sahara
Forced forum lurker that can't do what the mods asked for anymore since my Report button is gone and i'm not allowed to see the Site Issues sub forum or make new threads ANYWHERE
Ball joints are more of a press in thing than a bolt on thing. :) Teraflex, Dynatrac, Metalcloak, Synergy, there are many brands out there. In my experience it is likely the Ball joints or your track bar. I had to tighten my trackbar more than recommended torque at the frame side to get it to not move around. But even if it is your trackbar, if you have stock ball joints, they are probably bad.
Northridge has a good video about the different options.
MIne was both. Torquing the trackbar to the Clayton spec instead of the Mopar spec made a big difference too.
Boatbuilder88
Boatbuilder88
New Jersey
'19 Wrangler JL
F-16 Engineer (retired)
As most of us suspected, the dealer just replaced the steering damper. Ugh.
Anyone know of a shop in central Jersey that can help me diagnose the root cause?
CloakedWillys
Summit Sponsor (Level 3)
Will
Rancho Cordova, CA
www.metalcloak.com
18 JL 2.0T Sport S
Sales and tech support for MetalCloak
Globex will get you right.
yokramer
A Land of Petty Tyrants
Snark Incarnate
How did they take it when you told them you wouldnt take the Jeep back until they fixed the actual cause of the problems?
brconflict
Spring Hill, TN
2023 Wrangler High Altitude
I had death wobble with my 2023 High Altitude JL. And this is with 20" rims/street tires. Here's a few things I found and will be doing myself:
1. Older Mopar stabilizer is known to be "a fault", and dealers will replace this without even looking at the part # on the one you have. Even if your Wrangler has the new/updated stabilizer, they'll toss it and replace it with the exact same part. That's what my dealer did.
2. Replacing the stabilizer with a Through-shaft FOX stabilizer did not solve the problem (actually made it worse). So, I wasted money there, but I still have the stabilizer I'd happily sell for $120+shipping to the continental U.S. if anyone wants to try it. I'm sure it's a fine part, it just didn't fix this problem for me.
3. tires should be at a reasonably high pressure (at least 35 lbs for factory wheels on the High-Altitude; You situation may be different) while on the highway.
4. Replacing the stock stabilizer with a newer MOPAR part seems to have fixed the problem for me.
5. Replace the stabilizer every 50-60k miles.
That lat bit is interesting, because just as any other shocks will loosen over time, the stabilizer is no exception. It gets a workout, too.
Remorseless
NC
Holier Than Thou Internet Bully, Part-Time Online Boy Scout, Full-Time Arson Enthusiast, Napalm Compatible, Not Only The Guy Who Defines What A Jeep Guy Is, But Also The Guy Who Defines What A Jeep Thing Is, Guy Who Has The Authority To Do That
So you could say that the situation is stabilized
Jeep Wrangler JL Death Wobble {filename}
yokramer
Snark Incarnate
gek
Code Monkey
Just keep replacing the band aid on an open wound.
yokramer
Snark Incarnate
Sardaukar
Wisconsin
2023 JLUR 6MT, 2023 JT Sport S
Software
Ugh... My '23 JLUR with a 3.5" lift and 35" tires is currently at the Dealer for death wobble. They are already pushing the steering stabilizer. I originally took it to a reputable Jeep and 4x4 shop in the area and they did an alignment and made sure everything was tight, diagnosing the issue to a clicking and some play in the steel steering box. They indicated it should be covered under warranty since I only have 28k miles on it, so I took it to the dealer. I had four severe cases of death wobble just driving the one hour from Jeep shop to the Dealer near me. They wouldn't stop unless I got under 30mph.
brconflict
Spring Hill, TN
But what's the open wound and who created it, exactly?
High-speed motorcycles use stabilizers for the same reason, and they should be replaced occasionally. That's not necessarily because those bikes are flawed. They're just being modded and used for something that's perhaps a little beyond their original design. If Wranglers had independent front suspension that would certainly solve this problem, but at the expense of a straight front axle. This issue has been a problem for quite some time. Sure, there might be some flaws that make it more "likely" to occur, as I alluded, but would you trust a Wrangler with a straight front axle and no stabilizer at all?
Keep in mind, ball joints and other parts on the front end will and do wear out—sometimes prematurely. What I offered is simply how to deal with what's there now with less expense and to better solve the problem. After all, maybe even a band-aid is cheaper than an entire front end replacement.
By all means, if you experience Death Wobble while under warranty, report it. Get it fixed. Just know the manufacturer must take the path of least resistance first.
gek
Code Monkey
But a stabilizer doesn't solve the problem it masks it. Hiding something behind a band aid and fixing it are completely different. I don't know about you, but I prefer other people I am on the road with to have functional steering.
If you need a band aid in the interim until you can fix the actually problem that is one thing, but just ignoring the actual problem with a band aid over and over is terrible advice. Especially since it will only ever get worse.
yokramer
Snark Incarnate
Hey man hiding your zombie bite behind a long sleeve shirt is a valid strategy.
