Dead pedal for 2024?
S2k Chris
Arlington Heights, IL
AP1 S2000, Willy’s, Honda CB360 project
Food industry finance
I had a MORE dead pedal in my 2021, which I liked, but apparently no more holes in the 2024. I’m not interested in trying to drill my own (I’m a big dude, I could barely reach down there to install the MORE, I’m not convinced I could accurately drill in the footwell), so what alternatives are there? Any decent substitute? Also, someone said the 2024 4xe doesn’t have the holes, I assume the same is true for the gas Jeeps? Anyone confirmed? Looking for a solution for my inbound 2024 Willy’s 3.6L.
ellunchboxo
Baton Rouge, La
2024 Anvil Willys 2 Door
PetroChemicals
I ordered one from Amazon and have no issues with it.
https://a.co/d/0fZCxb2e
Jeep Wrangler JL Dead pedal for 2024? IMG_2108
Barchetta
Max
Franklin NC
24 JLRX Firecracker 3.6L; (sold) 02 TJ Sahara 2DR
How easy is it to remove the floor mat with that installed? I seem to always be pulling out the floor mat to dump dirt etc. Looks like a tight fit that might make removing the mat tough to do.
msudawg
Brent
Mississippi
2007 Jeep Wrangler JK
I got the Quadratec with the optional rubber pad and like it a lot. Mounts to an existing bolt and is on a hinge. So it is easy to raise up and stay out of the way to remove floor mats.
Opus
Midwest US
www.jlwranglerforums.com
That's the same dead pedal I installed yesterday. No drilling. Couldn't be any easier to install.
Same here. I've had it in for over a year now and it's held up well.
jludave
The Isle of Long
IT Manager
I don't know about the others, but the Quadratec dead pedal (which I have) flips up so theres no issue removing the floor mat.
rcadden
Ricky
Asheville, NC
Marketing
I have the Hooke offroad one, which is designed similar to that one. It's not hard to remove the mat, but it can be a little tricky getting it back in - the pedal will lift up a little (the bracket has some flex to it) so you just lift the pedal up enough to shimmy the floormat under it.
OR you could just get Armorlite and not worry about it anymore. :)
813 Fabrication & Design
Rock Sponsor (Level 1)
Jeremy
Louisville, KY
2020 Jeep Gladiator / 2022 JLUXR
This is the Dead Pedal I designed. The bottom flips up easily to remove the floor mat. Simple to install. Like most all Dead Pedals, it does not work for the 4xe. The 4xe is missing the firewall threaded stud that the pedal mounts to.
I designed my pedal with a little extra usage in mine. I use the Old School floor dimmer switch in our Jeeps. I have it connected to the Baja Designs LP6s on the bumper for the ultimate backroad bright lights. I can turn them on and off with my foot so no fumbling for a button to push by hand while driving. I also have a momentary switch option. Some customers are using that to control their air horns. I have one customer who uses it to turn cameras on and off that he has mounted for rock crawling.
Made from 1/8 aluminum with texture powder coat.
https://www.813fabrication.com/product-page/jeep-wrangler-jl-gladiator-jt-dead-pedal
Jeep Wrangler JL Dead pedal for 2024? Jeep-JL-JT-Dead-Pedal-01
Jeep Wrangler JL Dead pedal for 2024? Jeep-JL-JT-Dead-Pedal-05
Jeep Wrangler JL Dead pedal for 2024? Jeep-JL-JT-Dead-Pedal-08
Jeep Wrangler JL Dead pedal for 2024? Jeep-JL-JT-Dead-Pedal-11
Jeep Wrangler JL Dead pedal for 2024? Jeep-JL-JT-Dead-Pedal-13
Jeep Wrangler JL Dead pedal for 2024? Jeep-JL-JT-Dead-Pedal-14
Dover, NH
Jeep JL Rubicon 2 Door
Happy with my Metalcloak dead pedal. I like the rubber inserts and their customer service is the best in industry. Feels like I’m dealing with a local shop.
Jeep Wrangler JL Dead pedal for 2024? IMG_3495
Rotsam
Jason
Austin, TX
Very happy with the Metalcloak in my 2024 392 - it was a simple install and it flips up. I might powdercoat or paint it at some point since it's the only bare metal in the rig right now.
jellis4148
Missouri
I have the same one. Super comfy and like the adjustability of it.
