CV Joint Front Axle
kah.mun.rah
Merenkahre Jr.
Duat
Not an XR, I'm pretty sure all JL D44 fronts have them.
Edit 2024+ models.
Interesting. I wonder if it is related to the FAD also going away in the newer models.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
@JeepCares
Can you please clarify for us which wranglers get CV axles and which ones get traditional u-joint axles?
They usually don't answer those types of questions. At one point I built a database of those details, but can't anymore.
@AllMoparParts.com might be able to shed some light on that topic.
gek
Code Monkey
gek
Code Monkey
You mean that the universal one? The shop is not willing to work on that
Different shop? Or see if someone in the area that knows what they are doing is willing to help teach you how to do it for some pizza/beer/other food or drinks?
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
The data is not laid out by trim models, Its all based on sales codes. Here is what I can easily tell but will probably not be helpful
CV Front axles are used on
Dana 30/M186 Axles
Dana 44/M210 Axles
Dana 44/M210 Wide Axles + the HD Tube versions
- Benny
NeilP
Neil
South Dakota
2024 Jeep Wrangler Sahara Unlimited
RETIRED!
If it matters, my 24 Sahara has u-joints on the front axle.
gpassida
George
Northern CA
1982 Jeep CJ-8 Scrambler and a 2025 2-Door Wrangler Willy's V6/6MT
Does your Sahara have a Front Axle Disconnect or the block off plate?
Our 2025 Willy's has the block off plate and the CV joints. They may have changed to the CV's if there is not functioning FAD to transmit less feel to the driver on sharp turns on the street.
NeilP
Neil
South Dakota
RETIRED!
It has the electric disconnect
johneracer
SOCAL
2025 JLURX
Are you sure you want to introduce a weak spot into your Jeep? They can be easily destroyed by a branch.
Really? The boot can be damaged, but the CV joints are just about indestructible. The only time they fail is if the boot is damaged and you drive like that a long time. But if you are on the trail and pop the boot, you can easily make it home and replace later.
Pape
Quebec
JLU Sahara
Indeed, but would be fun to just not need to replace the boot at all when you puncture them :)
