CV Joint Front Axle
KevinBoston
Boston, ma
2024 Jeep Wrangler
I noticed that the front axle has a CV joint. I purchased a 2024 Wyllis and discovered the CV joint. My JK had u joints.
When did Wranglers go to CV joints? IS there an advantage or disadvantage of having CV joints.
As I remember, the jeeps with 4H auto had CV Joints
My Jeep 2 Door Willys with 2.0 Automatic
Jeep Wrangler JL CV Joint Front Axle 2024-Jeep Wrangler CV-Joint
NeilP
Neil
South Dakota
2024 Jeep Wrangler Sahara Unlimited
RETIRED!
My 24 Sahara has U-joints. I wish I had CV joints
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
You get CV joints if you have 4wd auto.
Base 4wd still gets u-joints.
AlgUSF
Melbourne, FL
2021 JLUS, 2014 Tundra, 2013 Odyssey, 2002 Civic
Ha! CV-Joint style axles on a solid axle vehicle, never thought that was a thing. I do like the design from an engineering standpoint.
KevinBoston
KevinBoston
Boston, ma
2024 Jeep Wrangler
I do not have 4-wheel drive auto. I have the part-time 4WD. I noticed that my 2024 Willys has CV joints. I had not seen that on a wrangler before.
I did read that the full-time system had the CV joints.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Must be something else that triggered it.
azwjowner
Phoenix
WJs had them. Was much smoother than my JL in tight turns.
JL.FR
Casa
France (Europe)
JLU RUBICON 2.0 Turbo MOJITO
Hello from France Kevin, since 2018 all models for Europe have constant velocity joints and all models have the full 4x4 permanent position.
KevinBoston
KevinBoston
Boston, ma
2024 Jeep Wrangler
Interesting, all Wrangles have the 4-High Auto or full-time 4-wheel drive.
I wonder what the advantage or disadvantage the CV joints are compared to the U Joint
CV joints maintain a constant velocity rotation of the wheel. You don't get the humpy movement that a U-joint front axle has when in 4wd and turning sharply.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
This.
I put RCV shafts in mine. It's a lot smoother in tight turns in 4WD then with the stock u-joints. Not so jerky.
