Cross-sections and wall thickness for various OEM suspension components
phageghost
San Diego, CA
2022 JLURD
Couldn't find any local buyers for some of my take-off suspension parts, so took a cold saw to them on their way to the glue factory landfill. Thought it might be of interest to share what these things look like in cross section along with some rough caliper measurements of wall thickness.
Tie rod (0.1475 in)
Jeep Wrangler JL Cross-sections and wall thickness for various OEM suspension components 6AD1378D-EBD4-4DB8-A928-9B5949DFCA7A_1_105_c
Jeep Wrangler JL Cross-sections and wall thickness for various OEM suspension components 9D0DF3C9-7508-4698-A92C-95713B0EB7DC_1_105_c
Drag Link (0.286 in)
Jeep Wrangler JL Cross-sections and wall thickness for various OEM suspension components 257B870A-876B-4A6B-BFA3-67C208F54A76_1_105_c
Jeep Wrangler JL Cross-sections and wall thickness for various OEM suspension components 788B13C3-454A-4A28-8C62-3BC813E78DE1_1_105_c
Front Trackbar (0.179 in)
Jeep Wrangler JL Cross-sections and wall thickness for various OEM suspension components E72EF450-1462-43B1-BD42-2266BE8E562F_1_105_c
Jeep Wrangler JL Cross-sections and wall thickness for various OEM suspension components 26A96F0D-3EE5-490D-B773-34FF2E1B314C_1_105_c
Rear Trackbar (0.126 in)
Jeep Wrangler JL Cross-sections and wall thickness for various OEM suspension components 92436A4C-7823-4CFD-AE7B-1382D36B6B67_1_105_c
Jeep Wrangler JL Cross-sections and wall thickness for various OEM suspension components 07A5E754-1ACE-4DF8-A9AC-F08EB5A75FA3_1_105_c
Front Driveshaft (0.158 in):
Jeep Wrangler JL Cross-sections and wall thickness for various OEM suspension components 0AED74A0-C500-4C6C-BA1A-92BCF8A72AD0_1_105_c
Jeep Wrangler JL Cross-sections and wall thickness for various OEM suspension components 988B91F7-316E-41FA-9E52-B71760697713_1_105_c
Rear Driveshaft (0.173 in)
Jeep Wrangler JL Cross-sections and wall thickness for various OEM suspension components 74270DFE-95B1-45A6-986D-E576215F9F15_1_105_c
Jeep Wrangler JL Cross-sections and wall thickness for various OEM suspension components ED3E43B5-62F9-4EEA-AA04-0EE812AFD7DA_1_105_c
word302
Oregon
JLU
Pretty cool, but the quality of the metal is more important and judging by the weight of these things it ain’t great. I’m actually surprised the drag link is that thick after tossing mine.
phageghost
phageghost
San Diego, CA
2022 JLURD
Yeah - I wouldn’t have guessed the drag link to be nearly twice as thick as the tie rod, but in hindsight it makes sense - the drag link handles all the steering force while the tie rod only sees half of it.
I was able to sell the control arms, otherwise I would have liked to cut them open - they were almost frighteningly light
jadmt
jeff
montana
I actually think the quality of the oem way better than people think.
jadmt
jeff
montana
OP, thanks for doing this. very cool. had not seen a stock DS cut in half before only twisted :)
AnnDee4444
'18 JLR 2.0
I've got a few non-suspension parts to add:
Stock crossmember forward-most tube (commonly removed when adding a skid plate). Asfir & M.O.R.E. skid plates were measured here: https://www.jlwranglerforums.com/forum/threads/2-0-engine-skid-plates.49229/page-19#post-1658896
Jeep Wrangler JL Cross-sections and wall thickness for various OEM suspension components pxl_20210918_151455476-jpg
Rear bumper brackets (OEM steel bumper, but likely the same on plastic). Metalcloak's brackets measured here: https://www.jlwranglerforums.com/forum/threads/oem-steel-bumper-rock-rail-improvements.90638/
Jeep Wrangler JL Cross-sections and wall thickness for various OEM suspension components pxl_20220310_012240736-jpg
Front & rear OEM steel bumpers. Also I believe this is the same as the OEM & Mopar "rock rails" (FWIW: OEM & Mopar are definitely the same thickness, just not 100% sure what I measured.)
Jeep Wrangler JL Cross-sections and wall thickness for various OEM suspension components pxl_20220324_003122793-jpg
Jeep Wrangler JL Cross-sections and wall thickness for various OEM suspension components pxl_20220324_003233077-jpg
AnnDee4444
'18 JLR 2.0
It also has to resist tension/compression of the entire axle assembly moving around, while the tie-rod's tension/compression limited to the wheel/tire/knuckle weight (assuming proper offset/scrub radius).
I'm surprised that the drag link & track bar aren't similar... I expected the track bar to be the strongest.
