Counter Balance Beads or Road Force?
rizion
Caleb
Houston
Wrangler JL 2dr Sport S
running 35" ko2 load E. Swapped wheels and can't get them vibration free. Shop I got the original wheels with these BFGs on them had to road force and it worked. But they will charge me to do it this time. Will Counter Balance Beads do the trick?
roaniecowpony
Retired Engineer
MOOG5050
Ny
Rubicon XR
I would pay for the road force. My shop can only balance up to 35s so i had to install beads in my 37s. They work 95% of the time well. But there are times you can feel an imbalance. Almost like the beads clump or dont go where they should. Eventually it smooths out.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Do you have a moisture filter on the compressor that you use on your tires? If not, that moisture will condense inside the tire every time it is cooler than the outside air, and cause the beads to clump until the tire heats up enough to revaporize the condensation.
MOOG5050
Ny
Rubicon XR
Probably not. It was the shop that filled them.
chadk77
Chad
Austinville, VA
2004 TJ, 2021 JLURubicon
I have 14oz of beads in my KM3 37s and it takes them a while for the beads to get where they need to go or unclump. Once they've heated up and I've driven a while they smooth out a lot. Was thinking about Road Force Balancing as well.
RamMan
Frank
Oklahoma City
JLU Sport Dsl. / '16 Ram PW / '14 GC Dsl.
Transport / Odd Jobs
Have had good luck with road force, & Centramatic Balancers,, expensive, but reusable. I don't run tall tires though. Also, don't use overload E on my Jeeps, extra weight to spin, harsh ride etc.
roaniecowpony
Retired Engineer
Good information.
MOOG5050
Ny
Rubicon XR
mine ride well enough that I don’t want to remove beads and remount but Centramatic will go on with next set of tires.
Old Dogger
Bill
Cave Creek Arizona
RFB, gives the most accurate balance.
Bandit59
Tennessee
2021 Jeep Wrangler 4xe
Road force alway better
MOOG5050
Ny
Rubicon XR
I agree that RF will balance more perfectly. That said, the stick on weights used can fall off or be pulled off when wheeling. And larger tires require more weight often so it increases likelihood. But do what works!
Bandit59
Tennessee
Like mine I have some wheels with a bunch of stick on weights Some with hardly any. But as now still smooth
Jtaugner
Upstate SC
23 JLURD / 03 Cobra
I know this is an old thread but I just had 12oz balance beads put in my 37" KO2's and I've got a slight shake @ 60+.. Does it just take time for it to work itself out?
