Coolant temp overheat
watchluvr4ever1116
Thomas
Michigan
Ok good that level is ok but will it fluctuate between warm and cold? Higher lower? Is the difference between warm engine and cold engine in each pic normal?
thanks a lot man.
You can only check it when it’s cold, so as long as it’s within those lines you’re good. After I discovered mine was low and I topped it off, the level settled and hasn’t changed since.
jimim
NEPA
2020 Rubicon, 2017 Tahoe LTZ
Needs to b
It has to be apples to apples. Always check in the morning when cold for comparison of any leak loss, otherwise you’ll drive yourself bonkers trying to make sense of the fluctuations.
Yes yes totally know that. I was just wondering about contraction expansion for my own well being. lol
jimim
NEPA
Ok thanks. Man I hope I don’t have a blown head. All Im thinking about. I keep the levels open on my radio screen now while driving. lol
jimim
NEPA
AM yesterday pic and AM today pic. Are we good?
Taken in my garage heated at 55 degrees before leaving for day.
Jeep Wrangler JL Coolant temp overheat IMG_5029
Jeep Wrangler JL Coolant temp overheat IMG_5047
jimim
NEPA
Both are within the lines. Today’s seems the littlest lower bit does that matter?
BillyToronto
Billy
Toronto, Canada
2019 JL 2 Door Sport, 2000 TJ
Jim, not to sound alarming but,
can you compare the colour of your coolant in tank with fresh coolant.
Pull a small amount out with a turkey baster or similar. Your colour looks way too dark to me, the coolant i get is pale and yours looks opaque.
Billy
JEEP4U
Richard
2021 Jeep Wrangler
Coolant combustion leak test needed.
Also, you can check your spark plugs. The cylinder(s) leaking will be super clean (steam cleaned). The spark plugs with the leaking cylinder(s) will be apparent.
and note..... you can absolutely have a head gasket coolant leak, where the oil is NOT being contaminated.
jimim
NEPA
i told them that at the service this week. . . no one listened to me.
ScotM
Scot
Southern California
2022 Jeep Willy's JL 2 Door
Agree with previous comments on color. I would not add any today. I would take another picture tomorrow, as it does look like there is some coolant loss from your picture. Another day will confirm it.
jimim
NEPA
Deff different color.
Jeep Wrangler JL Coolant temp overheat IMG_5050
