Coolant reservoir level question
Richardrocks
Oregon
23 Willys Sport
Why would the main one read near Min and the others over Max? Engine is cold.
Jeep Wrangler JL Coolant reservoir level question IMG_1988
Jeep Wrangler JL Coolant reservoir level question IMG_1987
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
This is normal. The MAX line is a service line for cold. As long as it's above the MIN and close to the MAX line, you'll be fine. With the fluid so close to the MAX line, you have nothing to worry about. It's not that sensitive where you're going to hurt anything. Service everything to the MAX line cold and you'll be fine. (You're perfectly fine as it sits right now, as well.)
mwilk012
2018 Ocean Blue JLU Rubicon
Service
The real question is, if they’re the same coolant, why are they different colors?
mwilk012
Service
I prefer the Grape flavor. Lol
The factory stuff is Strawberry.
I bought a Pacifica hybrid and it has 3 separate coolant systems and every one of them is a different color. They of course use the same as our Jeeps, some blend of purple/pink.
Richardrocks
Richardrocks
Oregon
23 Willys Sport
You ask a great question ☝ now I have to know…
Subman647
Roy Zeigler
Kingsland, Ga
2022 Wrangler Rubicon 4XE
Riddle me this one, Ours is a 2022 and the engine coolant recovery tank is black and you can't see the level. The other reserviors are clear???
Jeep Wrangler JL Coolant reservoir level question 20230424_121545
rhocking
IL
2020 Wrangler 2.0T JLU Sport S
Mine is a 2020 2.0t JLU Sport also has a black tank. This is the most annoying design ever. You have to unscrew the cap and use the dipstick built into the cap to check level. I seem to need to top off with about half a cup of coolant a month but cannot find a leak. Not sure if this is a problem or not. Is this amount of coolant loss OK?
My understanding was that the same coolant was supposed to be used in both the black (rear) coolant tank and the opaque (front) coolant tank. Are people using different coolant in different tanks or are the different colors coming from switching coolant brand and filling up/topping off with different color coolant?
