fdFifty
- Dec 19, 2018
- Pittsburgh
- 2022 Jeep Wrangler Rubicon
There’s a bleed valve on the back of the slave cylinder. Super easy to use as you can open/close it by hand. I’d recommend getting an inexpensive vacuum bleeder from harbor freight or Amazon for this job.I can bleed it myself I am sure, but this is one of the few things I have never done when it comes to cars. Do I have a bleed valve? is there a video or guide on how to do this that you can reference me too by any chance?
First step is to remove the slave cylinder from the bell housing so you can tilt it down. This makes the bleed port the highest point on the cylinder so no air gets trapped. It’s held in with two ( I think 13mm) nuts.
Next step is to hook up the vacuum bleeder and bleed the system by about 1 oz at a time. Be very diligent about re filling the reservoir up top. There’s a baffle/dam in there that actually fully separates the brake side from the clutch side. So you really only have the back 3rd of the reservoir of volume to bleed each time. While bleeding, tap on the side of the cylinder and hard lines with a small wrench or screwdriver. This will help free trapped air from the many pockets in the system and also knock bubbles from the inner walls.
Once you start pulling clean, clear and air free fluid you can remove the vacuum bleeder and cap the bleed valve.
Final step is a trick someone suggested to me here on the forum and it works great, you just have to be careful. With the slave cylinder still out of the transmission, slowly actuate the cylinder by hand. Again, be careful because you can blow out the seals. Try to keep the plunger as straight as possible and slowly actuate it. This process is going to push any remaining air back up to the reservoir and out of the system. Once that is done you can reinstall the cylinder and test everything out.
Make sure the slave cylinder is properly seated in the fork as well. If it’s resting to the right of the ball socket it will likely blow the seals. Unfortunately I’m not aware of any videos for this process. If I still had my 6 spd, I’d throw one together.
