intentsrig
- Brian
- Apr 8, 2018
- California
- JLU Sporticon
What size is the cotter pin?
I'm curious as well.I would guess its effecting a lot more people, that either dont have the windows down much or always have the music up.
On the bright side, fortunately for me there is this wonderful forums where I am able to diagnose every problem they come across on their Jeeps! Unfortunately for me, I seem to have every one of them. I this case, I also had the clicking noise in my front end. I just noticed it about a week ago and it seemed to get progressively worse, as if something was loosening up. For reference, my jeep isa 2018 JLU Sport. At 1000 miles I upgraded my stock sport tires and rims to 33x12.5x17 tires and a 17x9 rim. The Jeep currently has 2400 miles on it.
So instead of taking the Jeep to the dealer, which I’ve had recent bad experience with in dealing for other issues, I decided to tackle this problem myself.
I did not have a torque wrench, I instead used a box end wrench as well as a 1/2 drive socket wrench and socket. When I took the cotterpin out, they were pretty much ruined, so if you do this yourself you’re gonna need some replacement cotter pins to resecure the crown nut. The nut is 22mm and once the cotter pin is removed, I tightened the nuts down significantly. Probably past the factory specs. The bottom nuts were looser than the top ones, but they all got tightened and the cotterpins replaced.
This would be easier to do with the wheel side removed, because the cotterpin access can be a pain depending on which way the ball joint is rotated.
I attached two videos; one showing the noise that I was hearing, and the second showing the ball joints and explanation. Hopefully you all found this helpful!
My dealer told me the same thing and I told them the same as well. Yesterday, I took the wheel off and tightened the lower ball joint nut. I turned it and out 1/2 a turn. As I was turning it, it made the same sound. That fixed the clicking.Got back from the dealership. They told me the clicking noise was coming from my lift kit...since I put it on myself they wanted to charge me to look at it. I explained to them about this forum page and also that I looked over every bolt that I put on in terms of the lift kit. They didn't give a shit.
I'll be tightening these ball joints down myself...
You mention a steering problem with over inflated tires. What were you seeing and what psi are you running now? I randomly gets this "rattle" right up by the wheel, like a piece of plastic is loose. I take the wheel and adjust in and out up and down a bunch of times and sometimes it goes away.
https://www.jlwranglerforums.com/forum/threads/steering-feels-like-it-has-play-and-drifts.3691/You mention a steering problem with over inflated tires. What were you seeing and what psi are you running now? I randomly gets this "rattle" right up by the wheel, like a piece of plastic is loose. I take the wheel and adjust in and out up and down a bunch of times and sometimes it goes away.
