Clicking noise when turning.
rizej
Jared
Denver, CO
Has anyone had this problem come back? The replaced my front (left and right) bearing assemblies and everything was good but now I think I can hear some clicking again. I will keep listening to see if it's associated with low speed turning but I really hope I'm imagining this
EDIT: Also any tips for making sure the service department actually listens when you tell them to go ahead and tighten the ball joints to these specs? I feel like they just say "Yea ok we'll look at it" and then go do whatever they want
jerseyJL
vinny
new jersey
JLU rubicon
Check the cotter pins to see if they are moved or replaced and not in the exact same position. You can’t tighten the ball joint nut without removing that pin
Mercury191
Phillip
NB Canada
Wrangler JL Rubicom unlimited
Got my rubicon checked last week and they couldn't find a fix .Even show them the post where they replace all 4 ball joints but no luck ., . bringing it to another dealer tomorrow.
Now i just it a bump in the road and it snaps Everytime.
Kinda loosing my patience at only 2000k
jerseyJL
vinny
new jersey
JLU rubicon
Pull the cotter pins out of the lower ball join and tighten the nut about a half then. Click will go away. Replace the cotter pin
Mercury191
Phillip
NB Canada
I did tighten half a turn and still clicks. They are working on it this morning i will let you guys know if they find a fix,,
WXman
Central Kentucky
35 ft/lbs is an amount you can achieve without even using a large ratchet. That's not much torque at all. Which tells me that the lower ball joints are not supposed to be as tight as you can get them, and clicking noises are probably not coming from ball joint torque.
Mercury191
Phillip
NB Canada
Problem fix! It was the shocks nuts/bolts that was not tighten propreply on the shocks relocator from (2inch rubicon express spacerlift), they test drive it and no more clicking snapping sound, im picking it up tonight to re-test drive
Command Line RC
Cleveland OH
2018 Jeep JL Wrangler Unlimited
Hey Command Line RC,
Keep us updated on your dealer visit. As you may have seen throughout the thread, our team is available via private message and would be glad to help in any way we can.
Jasmine
Jeep Social Care Specialist
Here's my response. I took it to the dealership, they wouldn't look at the ball joints because I put my own lift on. When I got home, I took the wheels off and tightened my upper and lower ball joints...a 35 minute job.....no more clicking. I really don't understand what you all do besides speak to us in a private message. In my experience, their always seems to be this disconnect between you guys and the dealerships.
fat_head
2018 JLU
The dealer just called me and said they identified the clicking sound when turning left and its hub bearings. Parts have been ordered and hopefully that will fix it.
rizej
Jared
Denver, CO
Hopefully this fixes it for you but I took my Jeep in and they replaced both left and right bearing assemblies and it seemed good for like a month and now I think the clicking is back...
Sorbs
Brian & Sunny
Colorado Springs
21' Ram TRX, 20' Gladiator LE
Torque your lug nuts. They also may be loose.
rizej
Jared
Denver, CO
Check the torque on the lug nuts or ball joints? I live in an apartment building so I don't have as much room to work on my Jeep as I'd like so checking the ball joint torque is probably out for me...
Jonredjeep
Jon
Rubicon JL, Tundra TrdPro supercharged, LX570
Here I am again with the problem like you guys. I feel like im spending more time researching the problem with my jeep than actually enjoying it. Just notice Clicking noise in parking lot left and right turn. Taking this to dealer again. So many many problems.
Flyingtooth
League city,TX
2018 JL wrangler 4 door
My JL has less than 3000 miles. Been at dealer going on 5 weeks now. Replaced hubs, front axle and all kinds of other items. They can’t get clicking to stop. They want to bring in an engineer and sign off that vehicle is safe with the clicking sound since they can’t find the source. I’ll mention the ball joint and see their response and update if it fixes. Hard to believe Jeep hasn’t put something out on this as a bulletin.
Jonredjeep
Jon
reaching the 3k miles mark. All kinds of noise...when i brake the car there is noise.
When I turn there is noise. In the parking lot turning theres noise. Just noise.
