Chub rub
Trauma Jeep
Noah
Silver Zenith 2024 JLU
I recently installed 315/70r17 BF KO2s on my 2 inch Mopar lifted JLU. I also had the Mopar steel bumpers installed and the high clearance fender flairs. All this to say that the 35”aka 315 tier is rubbing on the rear bumper dispute installing the complete Mopar spare tier relocation and support kits. Has anyone else had this issue? Is there a fix?
Trauma Jeep
Trauma Jeep
Noah
Could you post some pictures so we can take a quick look?
Absolutely I thought after I hit the send button that I should included pictures lol. let me get some. Thank you.
Trauma Jeep
Trauma Jeep
Noah
Also, does that 3rd brake light relocation wiring look kosher? I feel like it should probably be in some type of shroud if not some thing a little more robust, giving in some protection against friction, etc..
Jeep Wrangler JL Chub rub IMG_0215
Jeep Wrangler JL Chub rub IMG_0213
Jeep Wrangler JL Chub rub IMG_0214
Jeep Wrangler JL Chub rub IMG_0212
Jeep Wrangler JL Chub rub IMG_0211
1BadDad
Zach
Tulsa, OK
2021 JLURD, 2023 JLURD
IT Innovator, Thought Leader
So, my spare tire reinforcement bracket on my 2021 that came with my order did not have the spare tire relocation included. I would like to see your setup with the tire dismounted to see if it has the 1"or so risers to the studs to get that carrier lifted up.
1BadDad
Zach
Tulsa, OK
For reference im running that same carrier with a true 38" without rubbing. Im MM's away but im not rubbing.
rohdawg
Long Island, New York
Merchant Marine
I’m thinking @1BadDad is correct. It looks like you might not have the riser installed.
Also, yup… the wiring is correct. That’s the way they have you do it. I wrapped mine up in Tesa Tape just to add some protection/piece of mind.
rohdawg
Merchant Marine
Can you confirm you have the two pieces I have pointed out installed? I believe I see the top one in your photo.
Jeep Wrangler JL Chub rub IMG_8734
dlong1119
Gainesville, FL
21 Sahara 4xe (StingGray)
Based on the Teraflex carrier instructions and which mounting holes to use, there is about an inch or so less clearance with the steel bumper, which the OP has, versus the plastic bumper.
I also agree, it's hard to tell if the Mopar riser brackets are in there, but I would think there'd be plenty of clearance if there is.
If you don't have them, I have a set available. Any chance you're in Gainesville?
Bryce
Bryce
Acworth, GA
2019 JLUR
My 315/70R17s rubbed until I did a 5 tire rotation. after the first rotation, it wore enough and it didn't rub anymore.
Edit: I don't have the relocation kit, but do have a Mopar tailgate reinforcement and 18.5x17+25 AEV Borah Wheels with BFG KO2 315/70R17 tires.
SWVA JLUR
Virginia
JLUR Wrangler
Here are some pictures of mine. Same tires (315/70 KO2s), steel bumpers, and mopar relocation kit. You can see how much space I have between the tire and bumper.
Jeep Wrangler JL Chub rub IMG_7552
Jeep Wrangler JL Chub rub IMG_7553
Jeep Wrangler JL Chub rub IMG_7554
Trauma Jeep
Trauma Jeep
Noah
Would you mind showing me a picture of what your tire carrier looks like without the wheel on it so I can show my service guy because he is insisting that it’s done right properly however I highly doubt that since you have no gap and mine is actually rubbing and we have the same situation basically thank you in advance
dlong1119
Gainesville, FL
An easy way to tell is look at how your carrier is secured to the tailgate. If it's on studs with nuts securing it, then it has the relocation (riser) brackets. If it has bolts holding it, then it does not. I don't see any way that you're fitment is that tight compared to the other pics above and am pretty sure you only have the reinforcement bracket.
Wabujitsu
Sarasota, FL
2021 JLUR, 2020 JLU Sahara
Retired US Army
To post what others are thinking - OP, I’m glad you didn’t post a photo of your “chub.”
