Changing from halogen headlights to LEDs
Buckster
Palmetto, FL
'19 billet silver JLUR, '25 Volvo XC60
Power Generation
These posts are great. I've yet to see anyone who can explain exactly why an LED bulb with the diodes in the exact same location/configuration as the elements in a halogen bulb cause this so-called "bleed" or "unfocused light".
Properly installed LED bulbs that are designed to replace specific halogen bulbs and are clocked correctly, will throw light in exactly the same pattern as the halogen. I've had the Beamtechs going on three years and I don't get flashed....at all. I'm lifted on 37's and my headlights have been properly adjusted.
It doesn't seem to matter how many pics are posted like those by @Htfan that show no scattered light and a clean cut off, the posts persist that seem to indicate that LED produced light somehow travels differently than halogen produced light.
OP - these are direct replacements. $40 on Amazon and the money you save can go to other mods. Don't be headlight shamed into spending cash unless you just want to.
Buckster
Palmetto, FL
Power Generation
Absolutely this. You’re not going to be liked by lost people on the road if you put LED or HID bulbs in a light meant for halogens. I think the equivalent of a tank of gas nowadays gets you a set of proper headlights. Don’t be that guy just to save 40/50 bucks on a 50k car.
Sorry, but I'm going to call you out here. LED bulbs in halogen housings work just fine. HID bulbs only go in projectors - so not relevant. Tank of gas costs me $75, LED replacements run from $250 for cheap crap to over $800 for name brand - so ???.
And you lost all credibility when you called it a "car".
blnewt
New Mexico
Just ask @cosine he knows!
Try the bulbs if you want, if you don't like them you're only out 8 gallons of gas :)
4xeEsq
PAss4xeesq
Wrangler 4xe
Call yourself out - a quick amazon search shows they start under 70$, not 250$. I’d bet money this cheaper headlight (1) has better light output than the 50$ light bulbs you’re suggesting people put in their reflector headlights and (2) doesn’t blind people on the road. Finally, I can imagine how cool of a person one must be to look down on people referring to their jeep a car.
https://www.amazon.com/dp/B086Y8HNSB/ref=cm_sw_r_sms_api_i_45RYRMHBHNFC8XSSHQJ0?psc=1
Gaffer
Central Oregon
2002 TJ / 2023 Sarah coming in the spring
Do all of these options require reprogramming like a taser or trip to the dealer?
blnewt
New Mexico
My RoughCountry/Oracle setup didn't require any taser or dealer software updates. Some aftermarket lights require a anti-flicker adapter to keep the CANBUS happy.
Cycle11111
Alastair
Truckee CA
2019 2 Door Wrangler Sport
I have the Oracle Oculus in my Sport and although I have a Tazer for axle and tire upgrades it was not needed for the LED lights. Tried bulb replacement and for me I did not like the scatter - yes I checked clocking. I love these lights plus I like the DRLs on the Oracles as well; also I upgraded my fogs and taillights to LED. Expensive sure, but after all the other items I spent money on to upgrade building my rig, it was the lower end of the upgrade pool of $s.
Medsker
Jon
South Jordan, Utah
I'm not sure about other peoples experience but here's mine with one halogen and one LED bulb installed. They look like the same cutoff to me and I was never flashed. I did adjust them down a little after installing the lift and tires but everyone should do that. I changed mine out for the LED headlights simply because I wanted to go with heated ones.
Jeep Wrangler JL Changing from halogen headlights to LEDs 20200203_093157
OldBlue
Doug
Chatham Twp, OH
See my Signature
Aerospace Forgings Test Lab
My 2¢ -
I've changed out the halogen bulbs in numerous vehicles, everything from Silverados, to F150s, to VWs, and yes, many of these were not successful. Too much glare to oncoming drivers or just poor results, so I switched many of them back to halogens. I can say that I've had the most successful results w/ LEDs in the stock JL halogen fixtures. We've noticed no glare to other drivers, and excellent results with a simple bulb replacement. See my post HERE.
jsw872
Ohio
2022 Willys Sport 2 Door 6Spd MT
I looked these up, it says for JL (need add Bracket) does anyone know what bracket?
Chupacabra
Greenville, SC
2021 JLU
That looks identical to what I saw when I put the Beamtech bulbs in mine too. Identical cutoff to the halogens. In 2 years I have not been flashed once, and I've tried driving towards my Jeep in another car and it does not seem obnoxious at all.
AntonioF
Antonio
Spring Tx
Wrangler Rubicon
do you need to program the computer when swapping for either LED bulbs or the entire unit options? what does that look like? What happens if you don't reprogram them?
Paluss
maryland
2022 JLURD
The halogen housing will support LEDs but it does not focus the beam correctly so there is light bleed towards oncoming drivers. The LED conversions are nice and cheap though. I would consider saving up some and buying a complete LED replacement housing (OEM or aftermarket). The entire housing is very easy to change out.
I agree 100%, the lights may look brighter, but may not shine much further down the road do to improper reflectors. Yep buy the complete LED housing
sailscall
Buffalo, NY
2021 2dr Sport 6MT
LED (either bulbs or whole units) draw a lot less power than halogens. The JL can sense low power and think the halogen bulb has gone bad. If you buy a CANBUS compatible bulb or headlight assembly that can fake the JL out to think it still has halogens. You will not need to reprogram. The explanation is very simplistic and may make some of our techie brethren cringe .
In my not so humble opinion you can
1) Buy decent replacement LED bulbs for $50
2) Buy non customer supported LED assemblies from Amazon for $250-350. The complaints on those are they have no customer service and there is not much light right in front of the JL. One JT owner drove around with his fogs to compensate and thought that was OK
3] Buy scratch and dent Rough Country LED housings on eBay when available - $160
4] Buy 7” LED housings with adapters to fit in the 9” openings of the JL - $250-350
5] Spend $500+ on awesome Oracles, Rough County’s, Or DV8s.
If I were to do it again I’d do option 3. Option 5 is my second choice. I do love my Oracle Oculus Bi-LED switchbacks.
Heimkehr
Pennsylvania
2021 JLU 2.0T
I'm rarely an early adopter where tech is concerned, but I was so with LED lighting technology. From experience, I can say that the subject is almost as contentious as engine oil choice, when either one is subjected to the tender mercies of online enthusiast forums. Like this one. ;)
Anyway, I've made my choice, and it's all good.
