CEL codes
2024 wrangler 4xe
Hi all! I have a 2024 4xe. Cel recently came on so I bought an OBD scanner to read the codes. Can anyone tell me what’s exactly these codes mean and if any are that serious? Any help is appreciated!
Jeep Wrangler JL CEL codes IMG_8951
HeN2O2
Shell Beach, CA
2023 JL Rubicon Diesel; 1983 CJ-8
Check all your fuses. Push down on each one to make sure they are fully seated. This is a common Jeep problem. The old joke in the 1970s was to never purchase a Jeep that went through the assembly line on a Monday during football season. Too many hung over workers. It seems today that whoever installs the fuses is either a girlyman that is not strong enough to fully seat the fuses or is just not very attentive to detail. My Jeep had loose fuses, loose PCM connection and loose can bus connections.
Also, close your fuel and charge doors.
2024 wrangler 4xe
I saw someone else had the p061b and p1444 codes dealing with the fuses. Just went out and about 20 of them weren’t properly seated. Smh
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
They'll work their way loose, especially if you use your Jeep for what it was designed for.
