CEL but no error codes
redelses
St George UT
2023 JLUR
The check engine light show up and stayed on for a few days. checked for errors and there were no stored messages and no DTC using a scanner (using one that I have and one at auto zone).
It takes forever to get into a dealer, so wanted to see if anyone had ideas/thoughts on this while waiting for that to happen. Thought it might be gas cap since it was fueled up the day before, but I thought that usually showed a DTC when scanned. This is on a 2023 4xe with about 10k miles.
Barney392
Lake Havasu, AZ
I used OBDLink to scan for codes and got none. I then scanned with JScan and it gave me 6 stored codes. All scanners are not the same.
jjvincent
Bethlehem, PA
2021 Wrangler, 2017 VW Alltrack, 2003 VW Eurovan
Mechanical Engineer
The security gateway can block codes what are not OBD2 yet triggers the check engine light. Thus many generic OBD2 readers will come up with no codes but a light.
redelses
redelses
St George UT
2023 JLUR
thanks. most should work with using the security bypass adapter? or can a tazer work without the bypass?
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Your scanner is insufficient. If you can’t properly read the codes what are the odds you can fix it? Get a dealer appointment, you’re under warranty.
