CB Antenna Mount Needed!
DickZip
S/w Florida
2018 Jeep Jl Rubicon
Jeep Wrangler JL CB Antenna Mount Needed! imag
What do you guys think? Ram mounts, I remove the CB mic mount and short arm when I'm not using it. I only use the CB for trail riding with a group, I have a lower mic clip to keep it out of the way. Love the phone mount, it always stays there.
DanW
DanW
What Ram ball are you getting that fits that fastener on the grab bar? That's a really nice set up!
MacombRoger
Roger
SE Michigan
2018 JLUR Ocean Blue
Solution Architect
Installed the @CoolTech setup. I'm happy with the way it turned out.
Hmmm, you went to the lower bolt. I still plan to go to the top bolt with a 3' whip, just peeks over the top. Not great, but good for trail communications. I got my Firestick in the mail today, still waiting on the other box from Cooltech. I heard that there was a shortage of radios, hopefully it comes soon. I need to modification so people don't think I am a Mall crawler. :)
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
Unfortunantly I wouldn't clear my garage with the 3' antenna using the upper hinge as a mounting position. I didn't want to have to think about removing it after a trip. I've done that on previous Jeeps and most of the time I was so tired when I pulled into the garage I forgot. Fortunantly it bent enough to clear the header but ripped all the insulation off my garage doors.
It sits about an inch lower than my softop. It will probably sit flush with my wife's hardtop when I find the time to install it.
Kadonny
Malvern Pennsylvania
2018 JLUR Manual Trans Front Spacers, 2010 JKU Wrangler Sport
Wow, do you really have a low garge?
I'm going with a 3' and a QD mount. Based on where I am now and the Cooltech measurements, I should fit just under my garage. If not, then I'll take off the QD.
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
I have a standard 7' garage, but my jeep sits fairly high.
The antenna sits 8.5" from from my garage header in the current location. From center of the hinge bolt holes to the tip of my antenna it is 37.5" tall.
If I mount it in the upper hinge I would be approx 1.5-2" too tall.
Fuel Fire Desire
Michigan
2018 JLU Sport S, 2020 JT Sport
Blkjak
Rock Sponsor (Level 1)
Rancho Cucamonga CA
gibsonleatherworks.com
2018 JL Rubicon
Technical Training Manager Mercedes-Benz USA LLC and owner of Gibson Leatherworks
I used a NGP unit from Firestik on both my JK and JL. It works really nice, and looks like a factory installed option when done.
I like this option the best ... any issues with the blind spot recognition
deitrick1
Rudy
Clearwater, FL
2020 JLR
I have not noticed, but to be honest, I haven't paid that much attention. I use it when at Rausch Creek and it does the job quite well when chatting with my group. The range is what's to be expected in the mountains. My JK had the 3' whip, while my JL has the 4'. I wish I had stayed with 3'. The 4' tends to wobble more due to length.
The really good news is this can be had on Amazon for around $50 including the whip.
DickZip
S/w Florida
Better put a spring on that thing, or u may end up with a hole on the side. Jl is Ito pretty for dat
HardRock
Beverly Hills, CA
2015 Rubicon JK Hard Rock Edition (FL); 2018 Rubicon JL (CA)
Agreed - great set up. I cannot locate that ball that bolts into the handrail on the RAM website...
deitrick1
Rudy
Clearwater, FL
2020 JLR
I ran a 3' with no spring for years on my JK with no issues. I actually bought one, but never used it. The antenna mount is pretty strong, but I'm thinking you may be right with the 4' whip.
