CB Antenna Mount Needed!
DanW
DanW
Nah uh, it's actually above it. It's clipped in like a standard wiring harness.
Ok, I'm going to go look again. I'll let you know...I feel like Mr. McGoo under there. I can't see :swear:.
Spank
Yeah, working under there is a bitch, too, but not having to fish wires through to the engine compartment is nice. This auxiliary wiring is something the Wrangler should've had years ago. Better late than never, I suppose.
DanW
DanW
Mine only has one. I'll try and get a pic. So, I'm guessing mine doesn't double back. If that's the case, which end should I start pulling to find the loose ends?
Edit....GOT IT! Thanks, @Spank ! Now to decipher which goes straight to power. I don't think I want to use up a switch....well, maybe. Maybe the button is good for this application?? Hmm.
Spank
The thinner red/white wire is constant power. That's what I've got mine going to.
Spank
How's it going over there, Dan? I've got mine all wired up and got the radio mostly tuned (could use a little more tweaking). I'm just still not sure where the hell to put this thing.
Jeep Wrangler JL CB Antenna Mount Needed! IMG_20180513_152619
DanW
DanW
Jeep Wrangler JL CB Antenna Mount Needed! 7hzHh51
Jeep Wrangler JL CB Antenna Mount Needed! vGGxhdo
Done! Pics coming momentarily....
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
Looks great! Do the screws go into the back panel as well(Rubber handle area?) If not watch out for the trim panel separating from the handle area.
I had my phone sitting there with a magnetic stick on mount and noticed the trim starting to pull out from the weight of my phone. I pulled it off so it wouldn't get worse, but now I have a slight gap between the handle and that matte bezel that surrounds the controls.
Spank
Dude. Awesome.
Jeep Wrangler JL CB Antenna Mount Needed! giphy
HardRock
Beverly Hills, CA
2015 Rubicon JK Hard Rock Edition (FL); 2018 Rubicon JL (CA)
Love it Dan W. Screw it right in - perfect location. I saw some photo posts around where the mic was handing on a bungie cord from the rear view mirror area. Not sure what the set up was but if you don’t want to drill it looked great and easily accessible.
DanW
DanW
No, it is a stick on. This thing is much lighter than my phone, so we'll see how she holds up. I'll fix it if it doesn't hold. That flat spot was put there intentionally by Mark Allen for microphones. I'm a little surprised they didn't reinforce it better.
I'm going to put another mic mount on the side of the center stack, down low, for my GMRS. Then, whichever is being used will be on the upper mount, and the one not in use will be on the lower, to the side. Below is the GMRS I'll be ordering soon. It is 15w and I'll upgrade to a good antenna. These things outperform CB's, big time. But, I gotta have a CB because most Jeeps I run with only have CB. Plus, I like to listen to and talk to truckers sometimes on road trips.
Jeep Wrangler JL CB Antenna Mount Needed! MXT275_front-view-600x429
DanW
DanW
Maybe get one of those retractable cord mounts that goes under your rear view mirror. Then, just have it up there when in use. If it stays facing you, the height and position will help you to hear the speaker. Those Cobras are great, btw. I've got one set up as a portable rig that I loan to friends who have no CB when we trail ride. I now I can tune my Bearcat to a full 4 watts, but I'm not sure it is as tunable as the Cobra, which I've heard can put out a little more.
I've thought about one of those retractable mounts. These little CB's with the speaker in the mic struggle with volume, so something that gets it up to ear level when in use might be good. I've got a buddy that is a trucker, so I'll ask him about different options.
islandtees
gary
florida
2025 Final Edition 392
I used the bracket from Cool Tech. No drilling.
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
Looks great, I'm ordering that setup for my wife and I Monday. How does it secure behind the bezel? Is the bezel easy to pull off?
DanW
DanW
I might go to that, eventually. The only drawback I see to it is that it slightly obscures the vent, which triggers my OCD. ;)
