Vinman
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
Finally got this thing 95% completed. A few more items to take care of.
  • fab a bracket to hang the on demand water heater from the upper exterior rail.
  • fab a bracket to mount a side table to the lower side rail.
  • mount propane tank on the tongue
  • and a few misc small items like curtains, interior hooks for keys etc and maybe a small shelf or two.
The trailer has a 15 gallon water tank located inside along with an RV water pump. I have a couple of spigots mounted outside that allows me to connect the water heater and have hot and cold at the sink faucet.
Power is supplied by 200 watts of solar feeding a 100 AH lithium battery.
The diesel heater is mounted in the tongue box with a bulkhead leading to the interior. Installed this way the trailer gets a constant fresh air supply with results in zero condensation inside.
I used the trailer a few weeks ago for a 3 night trip and couldn’t be happier, the diesel heater is beyond ridiculous, overnight temps were negative 12-15C and with the heater on the lowest setting I woke at 3:00 am and it was 28C inside. The following nights I slept with the roof vent wide open and even then temps were around 20 C.
The bed setup allows my current 38” wide tri-fold mattress but can be extended to fit ip to a 75” x 54” full size mattress. The bed is also raised enough to sit up while getting dressed and also high enough for a Dometic cassette toilet to fit underneath.
The goal of this trailer was to be able to pull into a site and be ready to use almost immediately.
Pictures in no particular order
Jeep Wrangler JL Built myself a DIY off-road squaredrop trailer IMG_8789
Jeep Wrangler JL Built myself a DIY off-road squaredrop trailer IMG_8790
Jeep Wrangler JL Built myself a DIY off-road squaredrop trailer IMG_8788
Jeep Wrangler JL Built myself a DIY off-road squaredrop trailer IMG_8785
Jeep Wrangler JL Built myself a DIY off-road squaredrop trailer IMG_8786
Opus
Midwest US
www.jlwranglerforums.com
ObiMatt87
San Antonio, Texas
2024 Anvil JULR XR, 2018 Mojito Sahara JLU, 2018 Buick Enclave Avenir
USAF Active Duty (Retired), DAF Civilian (Current)
Awesome work! Thanks for sharing. 👍
