ArmyRN
- Paul
- Dec 21, 2022
- Longview, WA
- 1946 Willys CJ2A, 1998 Jeep TJ, 2023 Willys JLU
On my 23 XR (with Factory BFG 35" tires) my uptravel is limited by my shocks (Fox 2.0 IFP for a 2 to 3" lift and the front IRO hydraulic bumpstops). It is 4 - 4.5" before the the shocks fully compressed. Remove the shocks and it's like 7" straight up before contact.Yes sir, we talked in your post, but I am not able to math out numbers for max uptravel/fender contact from it and not sure what tires you are running.
With one tire stuffed and the other fully dropped (pic below) it was 4" before contacting the inner fenderwell and fully compressing the shock.
Before you go spending a ton of money on your Jeep, I know you said you didn't want to add a lift, but add a set of Terraflex 0.5" spring spacers front and rear. Its easy to do. It won't affect your alignment, your Jeep will look just a bit better, and it'll give you another half-inch of bumpstop clearance up front. That's what I did way before adding the hydraulic bumpstops.
