Budget Bump Stop Extension Options?
WXman
Central Kentucky
I'm cobbling together an inexpensive lift for my Jeep. I'm now looking for 1.5 to 2.0" bump stop extensions. The prices I'm seeing are nuts. $80 for just a rear set? $120 or more for front and rear set? That's nuts for how simple the parts are, often just plastic pucks with a hole in the middle. So I'm probably going to just make something. Has anybody here already tackled this? Maybe you could share the ideas you came up with. I'd like to see what you did.
Gregj
Greg
West Texas
Get a polyethylene slab from that forest site and cut what you need. Cheap, easy and functional. It’s what I did.
Gregj
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
I used metalcloak bumpstops on the rear. The front; I bought 4 hockey pucks ($10) I bought SS bolts, nuts and washers ($10). It works fantastic and the best part, you can add & remove pucks without removing the spring. It's a little tight but I have done it several times. They're stackable, they work great!
Jeep Wrangler JL Budget Bump Stop Extension Options? Screenshot_20260124_180728_DuckDuckGo
Roky
Roky
https://www.jlwranglerforums.com/forum/threads/crystal-rubi-build….61821/post-2316900
Flip
Johnny
Virginia
Roky
Roky
Did your joust stops come with that hole in the center?
Mine did not. I cut a small V-shaped hole with an X-acto knife so it doesn't slide to one side. It's working great.
Yeah, that’s how they came on my vintage 2018….🤣 I’m using the MC jounce bumps now, much better….
WXman
WXman
Central Kentucky
Hmmm. I just stumbled upon Metalcloak bump stop replacements. They are allegedly 1" longer than stock and smooth out bumps too. Set of all 4 is around $100 bucks. I might be willing to do that for a simple solution, if they really are longer than the stock bump stops.
Flip
Johnny
Virginia
I'm so old school. 😥
Roky
Roky
Yeah they don’t compress the last inch….. they really do work good…here’s what they look like on…..
Jeep Wrangler JL Budget Bump Stop Extension Options? IMG_9176
Jeep Wrangler JL Budget Bump Stop Extension Options? IMG_9179
jondotcom
Jon
Bay Area, CA
2021 Wrangler JL Willys 2 door
Hockey pucks front like above.
For the rear, the 392 uses 1” cast iron bump stop extension that bolt on cleanly to the axle. They were around $35-40 shipped from the dealer if I recall correctly
68539877AB is what I used for the rear. You’ll need 2. Ebay prices are a ripoff for these imo
ColonelSanders
23 JLUR 4xe
Anyone that has done a Metalcloak lift probably has a handful of spare pucks. I’m no where near Kentucky or I’d hand you some.
if I ever plan to have my springs out again I’m throwing in the Metalcloak durospring stops up front. I came down hard off a hill and hit my bump stops once at Moab and felt my spine compress. Wife was not happy.
https://metalcloak.com/upper-front-durostop-bump-for-the-jk-and-jl-wrangler.html
Terrymo
Terry
2023 JLURXR 3.6 ET
When a diehard Rock Krawler fan is willing to use these, that says a lot. I bet you wouldn’t use them if they were gold colored.
