BDinTX
- Brad
- Jul 18, 2020
- Dallas, Tx
- 2020 JLU Rubicon Recon, 2021 JLU Rubicon
I have, correction “had” a couple of Smittybilt snatch blocks I bought 5 years ago. I figured they were inexpensive and if I needed one, they’d be better than nothing.
Yesterday my friend @Oh_Jeepers and I cleaned my winch lines, then proceeded to reload the winch under tension. We used a tree saver around a light pole with a 7/8” shackle connecting both ends to the snatch block. The Jeep was in neutral with the parking brake partially set to put some load on things.
When we got to the end and took tension off the snatch block, it fell apart. One of the shackle c-clips had come off and the center pin, without tension, came out on that side releasing the pulley. (sorry no pics of this)
The only other time I had used these was 4 years ago while helping install an emergency siren electronics box. If one of these snatch blocks had failed under load someone could easily have been hurt or killed. They now sit in the trash bin and will make a trip to the landfill tomorrow.
