Snatch Blocks - which to buy?
Graphite JL
Romeo, MI
2018 Sahara Unlimited
My old school Warn one is still going strong after 20+ years.
Compression-Ignition
Roy
Montana
'22 JLUR 3.0 Diesel, '20 6.7L F350, '94 12 valve
I just had occasion to finally use my snatch blocks recently. I have some TRE's and a couple from Safe-Xtract. I use good quality shackles and I do trust them, Skookum, CM, Green Pin. But there is no doubt that using soft shackles gives me the warm fuzzies over metal. The reason why I mention it is the soft shackles I have while oversized they did fit in the TRE snatch blocks, but not the Safe-Xtract. Just kind of an of note deal.
I see no issue with bringing back an old thread when it is loaded with pertinent information already...
WannFly
Priyo
Atlanta
2021 Rubicon 4Xe, 2026 MOAB
Cyber security
After reading this thread, I went back to Gear America site since I do have a bunch of items from them that I have bought over the years, some of them are now marked as Made is USA, not all, but some, which tells me they have moved some manufacturing back here.
I haven't used any of their gear in real world, so don't know how good or bad they are.
thelumen
james
usa
Rubicon 392
I just bought their 9T block and it seems decent for infrequent use. You would want some chafing gear if you use a soft shackle.
Joe Ba-na-na
Michael
Apple Valley, CA
2021 JLURD
Retired. Full time dog dad.
I use spools and soft shackles. Never a fail so far. But even if there was I can whip a fix together in a minute. I love modern ropes and don't miss the wire rope days at all!
Boomerang
Peak Sponsor (Level 2)
Boulder, CO
boomco.com
1976 Jeep CJ-5
It’s solid, affordable, and a lot of folks seem to trust it. Warn is great too, just a bit more pricey. Honestly, unless you’re doing super heavy recoveries all the time, the GearAmerica should hold up just fine.
Wabujitsu
Sarasota, FL
2021 JLUR, 2020 JLU Sahara
Retired US Army
I went with a heavy duty Rino USA snatch block. Probably a bit overkill, but I did recover a dump truck from my flooded pasture, once.
