Beginning of locker sensor failure?
Mhonda
2022 JLR
If a locker engaged inadvertently, say in 2wd, I assume you could just unplug the connector at the diff as a temporary fix to get you unlocked? Just to get back home, if one was stuck on the street with an engaged locker
Wabujitsu
Wabujitsu
Sarasota, FL
2021 JLUR, 2020 JLU Sahara
Retired US Army
How does disconnecting the cable cause the locker to disconnect?
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
The only way the locker can lock is by electricity coming through the harness. Unplug it and you get no locking. Same way a light bulb doesn't light without being in a light socket.
There is a really really miniscule chance the locker is physically broken and engaging because the springs inside the locker aren't keeping it unlocked. If you unplug the connector and the locker still engages, you need to pull the locker out and find where it's broken. But that is very unlikely.
mgroeger
Southern UT
2021 JLUR 2.0T
Mike, we both have a 2021 JLUR. The Tazer allows the rear to be locked in 2WD, but it’s not necessary. If you totally turn off traction control and press the OFF ROAD+ button, you can also lock the rear in 2WD, without a Tazer.
OK so this was on a 2018 with a Tazer so there is the answer.
mgroeger
Southern UT
2021 JLUR 2.0T
Yes, that is exactly what I did.
LukeDagny
Central PA
2021 JLUR
Mike, can a bad locker position sensor randomly cause the lockers to lock while in 2WD? If so, how so? I’m trying to justify the expense of the Z-lockers now, to the CFO of the household.
I've had a bad sensor for several thousand miles, and have not experienced any unwanted locking. I bought new sensors and potted them. I'm just waiting for the 40k mile mark to service my differentials and replace the sensors. I have less than 500 miles to go.
kah.mun.rah
Merenkahre Jr.
Duat
I saw the Z Automotive ones and said no f*cking way am I spending that. Funny thing is I watched their video about the Chinese knock offs that don't work so of course I went and bought those for a total $50 for BOTH.
The problem w the knock offs is the connectors have a little plastic ridge in them that doesn't line up with the ones on the Jeep. Well Mr. razor knife took care of that. Then I siliconed the heck out of the connections and voila... $50 vs. $340 and they work perfectly.
https://www.amazon.com/dp/B0CZNMBLF1?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1
Spends $70K on a Jeep and then would rather save $290 and risk being stranded on a trail than paying for the quality part. Can we see pictures of the duct tape that you used to cover the cracked leather in your corvette? ;)
Buckster
Palmetto, FL
'19 billet silver JLUR, '25 Volvo XC60
Power Generation
@Wabujitsu Going through the same thing but with the rear. Funny thing, it had been coming in and out for a few weeks, but work and other commitments have precluded me being able to address it. About a week ago, it came on and stayed so I figured it was done for good and too late to pot.
Now, it's been clear for a couple of days so I'm not gonna sweat it for the time being. Maybe rename her from Jolene to Christine....
Will likely go ahead and pick up the sensor kit ($125 from most online Mopar sites), pot 'em, and replace if/when it comes back for good.
Wabujitsu
Wabujitsu
Sarasota, FL
Retired US Army
Buck, is that something I could have you do at your shop, including the potting?
Jeep Wrangler JL Beginning of locker sensor failure? IMG_8824
Wabujitsu
Wabujitsu
Sarasota, FL
Retired US Army
So I had to take my Jeep to my preferred shop today, to replace the fuel filler assembly - the pipe/hose from the gas cap to the gas tank. It was leaking in an odd place whenever I fueled-up (see separate thread on that).
I asked them to check the locker sensor wire pass through for oil. Oil was following both lockers’ wire harnesses. I assume that means oil has already intruded into the sensor housings?
WannFly
Priyo
Atlanta
2021 Rubicon 4Xe, 2026 MOAB
Cyber security
There is likely oil inside the sensor housing long before that happened. Below in my rear sensor, the connectors in the passthrough area had zero oil in it. In front, there was no oil in the sensor itself, but the passthrough connector had oil on both sides.
about 40% of the sensor is filled with oil
Jeep Wrangler JL Beginning of locker sensor failure? 1750346009981-2v
mgroeger
Southern UT
2021 JLUR 2.0T
LOL! The reality is the guts of these harnesses are the same, It's a simple feedback circuit telling the computer all is well. I watched the ZAutomotive video on the issues with the Chinese knockoffs, knew that they could be mitigated with my large brain, and decided it was worth it. If nothing more than to say F you I'm not paying that much. Also at the time I was not looking to drop any serious money into the Jeep because I was selling it.
mgroeger
Southern UT
2021 JLUR 2.0T
Two totally separate issues. Funny you are seeing exactly what I saw on Fat Ninja my 2018 that @chevymitchell built. I too was in a frenzied panic and looking back I can tell you it's not a big deal. One thing of note, I REALLY like the bypass harness because it is INSTANT. The computer doesn't need to think to engage or disengage... ESPECIALLY disengage. Soooooo many times when rock crawling I'd have to fart around waiting for the lockers to disengage while the feedback sensor would, grab a coffee, take a $hit, read the paper and then decide to allow it to disengage.
