Beadlock Nubie Question
azwjowner
Phoenix
I have an XR as well. I found a screaming deal on the MOPAR beadlock rings on ebay so switched to beadlocks. The smaller off-road shops usually have no problems mounting beadlocks. Maintaining them isn't bad - torque wrench every other month and after a hard wheeling trip. I do have to dremel a few bolt heads to get the torque wrench back on it - the non-recessed design isn't great. Running hard trails at 8 psi without worrying about popping a bead or burping is great.
There's no way I'd buy the MOPAR rings at full price.
Keep in mind plenty of people run 8 PSI on the Method Bead Grips and don't pop beads either. If I were someone starting anew, I'd probably try those and see if I could avoid beadlocks altogether.
Atomic-Mouse
Northeast
I have had pro comp beadlocks on my Jk for about 8 years and never had any issues with loose bolts. The wheels came with Nord-Lock washers and even though I check them every few months they have never backed off. I have had Hutchinson wheels on my 392 since 22 without any issues. They use a locking flange nut and I have never seen any change in torque on them either. The Hutchinson wheels are DOT approved, the Pro Comps are not. I checked with the tech at my inspection station and he looked into if they were legal or not. In my state the only thing in the laws about wheels says they just need to be in good working condition, nothing about beadlocks. If it’s a concern, ask someone at your local inspection station.
I run beadlocks because I drop down to 10 psi for dirt roads for a smoother ride, in the spring I like to go snow wheeling and drop down to 5 psi, but I have no complaint with them aired up for highway use. I don’t think beadlocks are 100% necessary but I like the peace of mind especially down to 5 psi. I also think it’s easier to mount a tire on a beadlock wheel over a standard wheel if you don’t have a tire machine. You don’t need any tire irons to stretch the bead over the rim, it takes longer but less effort.
kah.mun.rah
Merenkahre Jr.
Duat
If you are airing down lower than 20 pounds on a non-beadlock wheel it is not if the bead separates and lets all the air out, its going to be when, and if you are running with a tire that has a Load Range "D" or less it will definitely be sooner rather than later for that when to occur.
I've been running 12 psi off-road for 20 years on non-beadlock wheels and never have had separation issues.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Load Range "C"s are for the street and not the Trail. Load Range "D"s for the dirt roads and Load Range "E"s for Trails with rocks and other obstacles.
Was there a significant amount of alcohol in your bloodstream when you wrote that?
Nokones
Kenny
Sun City West, AZ
23 Rubi, 21 Silverado, 13 Grand Sport, Cayman GTS,
Unemployed For The Rest Of My Life from a career of spreading love, cheer, and joy to lots of special individuals that were asking for attention..
Nope, but I bet you buy your gas at Costco and use the cheapest off-brand oil too and buy cheap counterfeit crap from a big warehouse type operation just so you can save a buck immediately and that is probably where you got your Pandaland load range "C" tires.
gek
Code Monkey
Terrymo
Terry
2023 JLURXR 3.6 ET
Yeah @Ratbert and all your substandard “pandaland” AEV and Next Venture stuff. Always trying to save a buck.
gek
Code Monkey
*Knock Knock Knock
Good morning, have You heard about our lord and savior, Amsoil?
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Terrymo
Terry
2023 JLURXR 3.6 ET
*Knock Knock Knock
I coat my load range G tires with Amsoil for less friction when I take the buggy lines. I had load range C tires in the past and while doing serious rock crawling, they melted and fell off. Load range G gets you home.
gek
Code Monkey
G's are gross. I make my own out of solid rubber from American rubber trees and I vacuum seal them to get all the air out for better traction. I call them Load Range U.S.A
Terrymo
Terry
2023 JLURXR 3.6 ET
Hell yeah…plus you fill them with cage free nitrogen right!?!
gek
Code Monkey
Caged nitrogen, can't let that shit get away. I paid $1000 for it at my local dealership.
3TV
Southwest USA
2022 JLUR 392, 2025 JLR
I actually have load range H tires. And I run them at 125 psi. They are on my Momentum 350G toy hauler. I haven't tried rock crawling with the toy hauler yet though. Maybe I should, LOL.
