Old Dogger
- Bill
- Nov 15, 2021
- Cave Creek Arizona
- 2013 JKR, 2016 JKURHR 2018 JLR, 2025 Gladiator Mojave.
- Occupation
- Retired
100% agree... It is taking a already weak cooler housing, and possible sending it into destruct mode..Probably the biggest concern I have is the added weight out on a long moment arm combined with the engine vibration which causes high G accelerations. In other words: a lot more weight sticking out a lot further. You're replacing the plastic cap with a chunk of aluminum that is north of a pound, then adding a steel can filter full of oil, weighing another pound or so, out another few inches, then you vibrate it with the engine pulses. When you look at how narrow the oil filter housing is, the few small bolts torqued to like 106 lbs/in or 9 lbs/ft, it gets looking pretty sketchy. If the plastic housings were warping and cracking before, my concern is how well they hold up to this significant added load.
