Baja Designs LP6
Ron-Short
Ron
St George, UT
2024 Rubicon 392
This is all I have at the moment but can take whatever you like later.
Jeep Wrangler JL Baja Designs LP6 IMG_0562
  • Love
Reactions: SKT
Ron-Short
Ron
St George, UT
2024 Rubicon 392
Do you have a view from the front? I have the same winch bar and was thinking of mounting up there but kinda like this better.
I looked at mounting them on the bolt to the outside of the hooks but thought this looked better.
I’ll take a dead straight on this evening. Anything special you want to see?
dcm80401
Golden CO
2022 JLUR 4xe / 2023 JLUR 4xe
Here is an alternative way to mount on a stock bumper (2nd photo). This is the BD mount for a stock plastic bumper. 1st photo is after a deer strike.
Jeep Wrangler JL Baja Designs LP6 PXL_20230118_190452788
Jeep Wrangler JL Baja Designs LP6 PXL_20221023_155800095.MP
Ron-Short
Ron
St George, UT
2024 Rubicon 392
I want to wire the backlight into the running lights. Any suggestions on where to grab the tap?
7.62x392
7.62x392
PA
2022 JLU Rubicon 392 XR
Ron-Short
Ron
St George, UT
2024 Rubicon 392
I did that initially I just wanted to make them flash whenever I lock the vehicle
dajuicejml
Justin
North Carolina
2024 JLRU 392
Get a fuse tap and go into one of the empty fuses that operate when the engine is on (same circuit as the DRL). I tapped into fuse F50. See my initial post below:
https://www.jlwranglerforums.com/forum/threads/baja-designs-lp6.122947/
Any idea if there is a fuse that would make the backlight run only when the lights are on that would prevent you from having to tap into the DRL harness? I hooked up my Hi/Low beams to the aux switches as well, but have not connected the backlight portion just because I haven't had time to dig into the wheel well liners. Tapping a fuse would be a 5 min solution.
Bbp
MD
M3, M5, Grand Cherokee, 24 Rubicon X
Any night time pics?
7.62x392
7.62x392
PA
https://www.jlwranglerforums.com/forum/threads/rubicon-392-fuse-box-diagram.77492/post-1614811
Also on the back of your fuse box top is the listing and what the main function is.
bobholthaus
Bob
St. Louis, MO
2023 JKURD AEV JL370; 2014 GC Overland Diesel
Technology Integrator
So based upon your pics above, are the low beam lights on when the high beam lights are on? I know BD says not to run them both together. But your pic above shows all lights on when the high beams are on. What am I missing? Thank you. They look great.
7.62x392
7.62x392
PA
No, low beam cannot be run at the same time as high. My low is hooked up to aux 1 and high to aux 2, and I use the lockout harness so even if I hit both by accident it’ll force high only. Only difference between low and high is that a few more of the LEDs are lit (2 vs 6, see my first pics on this thread). Pic above is a comparison of stock high beam vs LP6 high beam.
bobholthaus
Bob
St. Louis, MO
Thank You. When would you run low only?
