Baja Designs LP6
Beachbum66
Rafael
Santa Rosa Beach, FL
2019 Jeep JLR
Engineer
I love my LP6!
Jeep Wrangler JL Baja Designs LP6 IMG_2571
bthomp
Bill
Fort Collins, CO
2021 Wrangler 392 XR, 2023 Rubicon XR, 2010 Wrangler X, 2014 Mustang GT
IT Operations
LP6 up front, squadron pro on the A-pillars. As others have said, very bright. I'd like to get the mopar winch guard, but like the lights where they are.
Jeep Wrangler JL Baja Designs LP6 Screenshot 2024-12-17 at 8.44.57 PM
BajaDesigns
Rock Sponsor (Level 1)
San Marcos, Ca
Non-Applicable
bthomp
Bill
Fort Collins, CO
IT Operations
Just a heads up we are still offering the free SAE upgrade if you want to send them in. 👍 All info is in the link below.
https://www.bajadesigns.com/sae-upg...dTQDZgovJeGh573MCm32TvMoHXfjz-b0GAqx0sv7sLAny
Best,
Brahian Herrera| Forum Sales & Support
Email: [email protected] | Phone: (760) 560-2252
Thx! How do I know if I have Gen1? These came on my 392 when I bought it used. Not sure if the last guy already handled it.
Separately, how can I tell if mine were set up correctly to not damage them if I accidentally use the high and low simultaneously? Mine is wired to the factory aux1 and aux2. Thx.
BajaDesigns
San Marcos, Ca
Non-Applicable
The fog lights have a black shield on the lens. Below is an example of our GEN 2. You will see big performance gains and it's completely free!
Jeep Wrangler JL Baja Designs LP6 1734554372221-mo
If the harness comes with a relay, then you have our lock-out harness, and it is meant to protect your light if you ever accidentally turn them both on at the same time. If no relay is visible, then you are just running the wire from the light to the Aux switches. If that is the case, then you will just need to remember or simply discount the low beam to prevent it from happening.
Best,
Brahian Herrera | Forum Sales & Support
jeffdlinn
Castle Rock, CO
2023 Jeep Rubicon 392 XR
Finally received both @Baja Designs LP6s and the harness. Installed last night / this morning. Overall install was pretty simple with the BD upfitter lockout harness. I hooked the low and high beams to the factory Aux switches 1 and 2 and the backlight to Fuse F50 (always on when the ignition is on) via a fuse tap. These things are stupid bright, and I think really complete the look of the front end.
Backlight, always on when the Jeep is running:
Low beams (Aux 1):
High beams (Aux 2):
The BD lockout harness (pictured below) will lock out the low beam if both Aux 1 and 2 are active to prevent burning the lights out (per BD, running both high and low at the same time will burn up the circuitry in the lights):
Fuse tap into F50 for the backlight is pictured below, cut a small hole into the fuse box to run the wire through. The harness is very long and leaves way too much extra wire, which I had to just stuff next to the fuse box. I’m out of space now with the factory Aux switches. When I get the cowl lights I’m going to also get the SPOD BantamX touchscreen switch panel, at which time I’ll cut down the harnesses and clean up all the wire. The BantamX has a lockout function so I won’t need the relays in the BD harness I’ll cut them out.
Does the location of the LP6 interfere with the front-facing camera?
UTME
T
2024 Rubicon-X Unlimited
Here is an alternative way to mount on a stock bumper (2nd photo). This is the BD mount for a stock plastic bumper. 1st photo is after a deer strike.
Are the wheels method 703? Looks great!
