AUX Switches: Cable COLOR CODE Wiring Identification
Marlene
Marlene
Melbourne, FL
Jeep Wrangler JL Unlimited Sport S
Graphic Designer
Today we installed a lighted whip on the back of the Jeep (mounted it on the tire carrier, relocation bracket / mount).
After much research we wanted to help and/or save others time finding and identifying the AUX cables.
Here is a short video and photo showing the wiring color codes and where to find them to install your Jeep accessories, which will work with your AUX switches.
The interior AUX cables / wires are located inside front passengers side footwell area or foot kick plate area (as the video and photo below shows).
Hope it helps!
Jeep Wrangler JL AUX Switches: Cable COLOR CODE Wiring Identification 2018-jeep-wrangler-jl-auxiliary-switches-jpg
NOTE: SOMEONE MENTIONED I HAVE AUX 3 and IGNITION SWAPPED, PLEASE DOUBLE CHECK THAT....
Jeep Wrangler JL AUX Switches: Cable COLOR CODE Wiring Identification Jeep Acc
Also underhood locations (posted by @Brazilbombsqd):
Aux Switch 1 F93 - 40 Amp Beige/Pink Interior (passenger side under instrument panel) & Underhood (right side near battery)
Aux Switch 2 F92 - 40 Amp Green/Pink Interior (passenger side under instrument panel) & Underhood (right side near battery)
Aux Switch 3 F103 - 15 Amp Orange/Pink Interior (passenger side under instrument panel) & Underhood (right side near battery)
Aux Switch 4 F108 - 15 Amp Dark Blue/Pink Interior (passenger side under instrument panel) & Underhood (right side near battery)
Battery F72 - 10 Amp Red/White Interior (passenger side under instrument panel)
Ignition F50 - 10 Amp Pink/Orange Interior (passenger side under instrument panel)
Also see other AUX switch discussions @ https://www.jlwranglerforums.com/fo...switches-configuration-installation-diy.1477/
Ormond Beach, Florida
Retired at 55 ..
8/12/21 Update .... Must Read...
IMPORTANT: Do know that if your JL/JLU has Aux switches that were installed at home, a shop or at the dealer and not at the factory, that you need to read at the links below....
Read at the links directly below.... then read the rest of the posts in this thread.
https://www.jlwranglerforums.com/forum/threads/aux-switches-cable-color-code-wiring-identification.13026/post-1612084
https://www.jlwranglerforums.com/forum/threads/aux-switches-cable-color-code-wiring-identification.13026/post-1612377
Gdub
Geoff
Tucson az
2018 JL Sahara
Engineer
I assume these are the same for under the hood connections?
Marlene
Marlene
Marlene
Melbourne, FL
Graphic Designer
Retired at 55 ..
Yes, the same same under the hood. Do know though, that the Aux kit that is installed by the owner only has 4 wires. No Direct to Battery and Ignition/Acc wire.
Remember, if you use 1,2,3,4 under the hood you can't use the same in the foot well and vice versa.
Torero
J. Diego
Illinois
JL Rubicon, FJ Cruiser, BMW Z3, F650,GL63 AMG, STI
You can’t use outside and inside wiring or you can but both things will be energized at the same time? Is it so sophisticated that if you use both none will work? Or only the first one used remains working?
How someone could think that the same switch could power two different things independently? How would it be decided?
Retired at 55 ..
@Torero
Not sure what you are asking... but ............... you could put say an led light on Aux3 under the hood ,and another say led light on Aux 3 in the foot well, but when you press Aux 3 button, both lights would light up. Only makes sense right....
This is pretty elementary to me but to some................. well some are lets say out of their element and clueless ....
No, it is not that sophisticated. It is a simple switch that has to places to play with but you use only one.
Torero
J. Diego
Illinois
@Torero
Right. That’s common sense to me. It’s just semantics, people keep saying you cannot do this or that, when you can, even if it doesn’t make a lot of sense.
Brew211
Peoria, Arizona
2018 JLURM, 2022 392 XR, 2024 F250
Question, how are they wired inside and under the hood? I'm so confused!!!!
Retired at 55 ..
@Brew211
There is alot of info in regard to the Aux Switches and the wires you use with them. Do a forum search..
In the short of it, if the factory installed the Aux Switches, you will have two different places to get the wires that the 4 Aux switches, switch / provide power to. You have a bundle of wires right by the battery and a bundle in the passenger foot well. See the pics earlier in this thread.
Now, if you install the OEM Aux Switches yourself then what you end up with will be a tad different. Again, a forum search will give you a scad of info on Aux switches.
IF you have any particular questions, post clearly, your questions, here and you will get answers...
Brew211
Peoria, Arizona
@Brew211
Thanks for the clarification, I’m just impressed that they pre-wired two locations to connect to. Thanks again.
Brazilbombsqd
Arkansas
2018 JLU Rubicon
Jeepsterfreak
Honda, Future JLU
Is the aux switch programming available in the base UConnect 3 or do you need UConnect 4 to change the switch behavior?
sirryan
Ryan
Clarksville, TN
2018 JLU Sport S
I have the aux switches from the factory, but don't have the direct to battery or igition accessory...hmmmm
