Auxiliary (AUX) Switches Configuration/Installation DIY
JAY
Administrator
Administrator
Jay
Wrangler
Admin
AUXILIARY SWITCHES
Four auxiliary switches located in the lower switch bank of the instrument panel can be used to power various electrical devices. You have the ability to configure the functionality of the auxiliary switches via the Uconnect settings. All switches can be configured for setting the switch type operation to latching or momentary, power source of either battery or ignition, and ability to hold last state across key cycles.
The auxiliary switches control relays that power four blunt cut wires located in the interior passenger outboard foot well area and on the right side of the engine compartment near the battery.
In addition to the four auxiliary switch wires, a fused battery wire and ignition wire are also located in the interior, in the passenger out- board foot well area.
Conveniently, Jeep also includes a kit of splices and heat shrink tubing provided with the auxiliary switches to aid in the connection/installation of your electrical devices!
RonH
Ron
Deming, NM
2006 Ford F-150, 2018 Granite Crystal Metalic JLU Rubicon
Retired AF, Now Field Engineer / Site Manager
Had no idea that they could be configured for momentary/ignition/on, etc... Nice feature to be able to configure them. This will be my first Jeep, and I get more and more comfortable with it each day. See ya later, Ford...lol
TroyBoy
Troy
Vancouver Island, Canada
Any idea the wire guage and amp rating?
BillyHW
CAN
I wonder if it will be possible to connect these switches to devices on a secondary battery in a dual battery kit.
TroyBoy
Troy
I'm guessing not without another relay.
domleeds1919
Dominic
MD, USA
2006 Saab 9-3 Aero; soon to be JLU owner!
I'm assuming this is something that can be upgraded to at a later date if no selected as an option when purchasing the Jeep?
AZCrawl
AZ
2018 Granite Jeep JLUR
Yes, just more expensive, since you need to account for labor.
domleeds1919
Dominic
MD, USA
True, but I’m assuming it wouldn’t be too difficult to install on your own and most likely there will be a good video/write-up for doing it, just like for an LED headlight upgrade. In place of the Aux switches are likely just false blank buttons as “place holders” in case it’s upgraded later.
AZCrawl
AZ
It could be difficult, we don't know yet. Ripping apart the dash, running and sealing stuff through the firewall, etc. Probably not trivial.
Texas_Yote
Kris
Prosper
www.instagram.com
18 JLUR Granite, 15 JKS 2DR, F80 M3
Slang 1's & 0's
I wouldn't be worried about the physical aspects of the install, it's not hard to run wires. But if you want it to be configurable like it mentions in post #1 the association with UConnect just made a mirror install more costly and difficult.
I am going through the process of doing a factory install of power windows and locks on my daughters JK. I have scrapped the original plan and going aftermarket as the dealer needs to get involved in programming once it is all installed.
My guess this is going to be literally 5x cheaper to do in the order vs after the fact..
Socceref
Ref
Oak Park, CA
JLU Sahara (loaded)
Trivial question, but.. any clean solution to replacing the buttons or labeling? Instead of Aux1 > CB Aux2 > Trailer . I have tape and a pen. I was hoping for the best and cleanest options. All ideas are appreciated.
OldGuyNewJeep
CT
To be fair, Raptor has had aux switches since 2010... I miss my Raptor! (But am psyched for my new JL)
RonH
Ron
Deming, NM
Understood...and SPod has been out a while as well...plus one other I can't remember the name of. Point is, upfitter switches that are OEM are rare. And, after looking at the Raptor, with it's associated MSRP +++ pricing, I'm glad I went this way. The switches are just icing...
usmcss
Bob
Illinois
Black 2018 Rubicon JL
Well I see wiring but can’t seem to find what the manual is stating:
Bestop
