Aux Battery Delete - Need Help!
Voodooridr
Idaho
2020 JLU WILLYS
Well that does look fairly easy, we already have an auto stop start eliminator installed so the aux battery is kind of unnecessary
sided03
Siddarth
Maryland
2022 wrangler sport s
Remove fuse F42. Then disconnect aux battery negative and isolate. It should be the thinnest of the negative cables on the 2020.
I have question When I disconnect aux battery will aux switch still work ?
Even my main battery is draining slowly, too I’m want to switch it to Odyssey battery.
I want add 30 inch bar light , double 3inch lights and winch future.
jludave
The Isle of Long
IT Manager
Aux battery has nothing to do with aux switches.
sided03
Siddarth
Maryland
Awesome thank you
What think battery
Odyssey Battery ODP-AGM48 H6 L3 Performance Series Battery for 12-24 Jeep Wrangler JL &
AndySpill
Andy
Pittsburgh
2018 JL Sahara
Awesome thank you
What think battery
Hi Siddarth:
I take no issue with the quality of Odyssey Batteries, but do believe that when it comes time to replace a JL battery that owners should replace it with a group H7 battery (rather than a smaller H6) as per the following:
https://www.jlwranglerforums.com/forum/threads/main-battery-replacement-talk-jl-jt.100534/
Depending on how a JL is outfitted by the factory it may come with an H6 or H7 battery. But if you read the thread attached you will see how an H7 will fit regardless, and I believe, the increased cost, if any, justified by the increased power.
Good luck.
jludave
The Isle of Long
IT Manager
Go Hogs!
Arkansas
2022 Jeep Wrangler Unlimited Sport Altitude
If I completely remove the aux can I just tape off both cables on the aux side and leave everything attached as is on the main battery? 42 fuse is already pulled.
jludave
The Isle of Long
IT Manager
Sure.
Go Hogs!
Arkansas
that’s a decision I will have to make this May when my warranty expires. I currently have the bypass done but am strongly considering just removing it completely.
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
The day has finally come: my battery died after less than 2 years of ownership. Now, I’m fully aware of the aux battery (AKA the parasitic battery) issue, and have researched the topic thoroughly, but I still have a few questions.
The way I see it I have a few options: replace the aux battery. Aux battery delete by removing battery, taping the wires, and pulling fuse 42. Buy a tazer/mini and turn off ESS. Buy an ESS bypass cable.
Questions:
If I delete the aux battery, do I have to feed the aux ground up to the main battery and connect it? Which cables do I need to tape and which do I need to connect to the main battery? Keep in mind I have a MY23, and I’ve seen conflicting reports that my MY has different cables.
If I buy a tazer/mini/ESS bypass cable, do I still have to replace the aux battery? Will the parasitic battery drain the main battery with these tools on?
Appreciate any insight into my questions. I’m trying to figure out the best option before I start down this path. I have upgraded the main battery with an H7 and I don’t want the parasitic battery to deplete the new battery in any way.
Fwiw, I went 4 years on original batteries before I traded the Jeep this year. I was using a Tazer to disable ESS. Bang for your buck it's hard to beat, lots of features. Watch the classifieds for a deal.
jludave
The Isle of Long
IT Manager
I have the bypass done and the aux battery is still in place. There is no negative affect/downside to just leaving it. I see no reason to remove it, since with the bypass it isn't doing anything.
sided03
Siddarth
Maryland
Hi Siddarth:
Good luck.
Thank you. I’m going with H7 94R no one has Odyssey my area . What are the other Brands are good
Go Hogs!
Arkansas
no danger of leaks or anything over the years? If not, I will probably just leave it in there.
JEEP4U
Richard
2021 Jeep Wrangler
XS Power or Odyssey.........Order from Summit Racing online
