Are SGW Extensions Necessary?
The Fixer
North Jersey
2018 Mojito! JLS, 2018 Firecracker JLUSS
Teacher
Just ordered the SGW bypass cables and vLinker MC+ so I can use Jscan. I've been reading through the threads and saw extension cables mentioned in a few of the threads. I don't know how often I'll need to connect the Jscan - I'm going to reprogram mine for 35s, and my son is getting paddle shifters for his '20 JLUR so we'll need to add that in.
So, do we need the extension cables? Or can I just use the bypass cables when necessary?
NULL POINTER
Carmine
Free state of Florida, NW of JAX
2024 Gladiator Rubicon X, '19 VetteZ06 7spdVert,4
Old Fart
It depends how much you like cursing, bruising your hands, and contorting your body in unimaginable ways to disconnect the SGW connectors from their origninal location.
EDIT Although I will say that the 2018 are much easier to access than the 2024's, but still a PITA. But NO, you do not need the extension cable. It just makes life easier the next time you need to connect.
CarbonSteel
You don’t need them if you don’t mind leaving blood and skin cell DNA under the dash. Or enjoy swearing at inanimate objects.
100%. On my 2019, there was not enough clearance for my large hands and I would inevitably cut my hands on the sharp metal or on the clips.
Totally worth it in my opinion.
The Fixer
The Fixer
North Jersey
Teacher
Thanks for the quick responses!! I am a short guy with small hands so I guess I'll see how bad it is. If I have to bleed, then so be it :CWL: . Wheels and tires are in the garage and the vLinker is coming tomorrow so I was hoping to toss them on after work and get it programmed. If it really sucks I'll order the cables for my son's JLUR when we have to program the paddles.
LARSONEM
Eric
Eaton Rapids, MI
2022 Jeep Wrangler Rubicon XR Unlimited, 2021 Jeep Willys 2 door
Much easier to connect and disconnect with the extension cables. I’ve got them in my 2022 JLRU and they make a world of difference. I just added a 2021 Willys 2 door to my fleet. It does make things easier.
The Fixer
The Fixer
North Jersey
Teacher
These are what I need to disconnect and connect my cables to, right?
Jeep Wrangler JL Are SGW Extensions Necessary? IMG_7696
NULL POINTER
Carmine
Old Fart
This is what I need to disconnect and connect my cables too, right?
Yep. Good luck.
Should not be too bad. You don't have the premium sound system amp in your way. My 2018 was much easier to do than my current 2024 with all kinds of stuff jammed up in there.
Still worthwhile getting the SGW cable extenders from Z automotive.
The Fixer
The Fixer
North Jersey
Teacher
Yep. Good luck.
Gotcha. My son’s JLUR has the premium system in it, so I’ll probably get the cables for his. Will keep you guys posted!
Tread4Lo
22'JLURD
I didn't get an extension. I do have a long flat head screwdriver with a bent head. This way I can push the clip in and pull at the same time. No blood and no extra cord to hide.
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
