Zandcwhite
- Zach
- Sep 4, 2019
- Patterson, ca
- 2019 jlur
Aside from 1st gear, gearing axles does absolutely nothing to “make up for loss of power”. 4.10 gears in 7th gear have the exact same final drive ratio as 5.13’s in 8th. I’ve yet to drive a JL with an 8 speed regardless of gearing or tire size that felt sluggish off the line, but maybe your experience is different? Having run 4.10’s for tens of thousands of miles on 33’s, 37’s, and 38’s, and then 5.38’s on 38’s I absolutely feel the Jeep was better off geared too high than too low. The mpg was worse, somehow the 0-60 even got slower, and the thing felt like it needed another gear on the freeway. Now with the new XR, even the 4.56’s and 35’s seem a little lower than optimal for me. Not enough to regear, but I think they will be a perfect match for 37’s for my use. We live at nearly at sea level, but wheel well above 10k’ regularly. I’ll never gear another JL in the 5’s unless it’s running 40“+ tires.It all depends on what you want to do and how tolerant you are of loss of power. You could re-gear your existing setup a lot cheaper than buying a whole new Jeep, but I get it sometimes you want something new.
You will likely find that 4.10 and 35's are still inadequate depending on elevation, use case, etc.
Generally speaking, this is what I recommend and have done--I re-geared twice:
3.6L/ZF8:
33" = 4.56
35" = 4.88
37" = 5.13
38+ = 5.38
