Another 3.6 thread… bulletproofing?
ajbarbier
AJ
2018 Jeep Wrangler Sport S, 3.6
I just bought a 2018 sport and I’m in love with it. Trying to take preventative measures to make sure I don’t develop lifter tick or anything involving coolant issues. I already know I have a small leak already- so that begs the question: what can be done preventatively to keep the engine healthy? I know the 3.6 can be very reliable. I also know it can be very unreliable.
So far what I have is-
Aluminum oil filter housing
Rpm fan controller
Baxter oil drain back.
Let me know what else?
Richard_JL
Larry
Boca Raton, FL
2026 JLU Rubicon 3.6L
IT Director
Mopar new version oil filter housing.
Change oil every 5K miles or so.
Keep up on the other fluid changes.
Enjoy!
I may be behind on this, but isn't the 'new' Mopar oil filter housing just as crap as the old one (made of plastic)?
The OP indicated he is using a new aluminum one (hopefully good brand).
c20040215
Leon
The oil leaking is caused by the poor o-ring design. The cracking is caused by over tighten the filter. None of those are caused by it being plastic. I would go with the updated Mopar version. In my opinion, Dorman is where I would go when I run out of all options.
garyji
Gary
Western NC
97K on mine, and it's been perfect. Oil changes every 5. I did the plugs at 90k and had them (my shop, not a dealer) put in the new design OEM oil filter housing just as a preventative. I do my own oil changes, so no oil monkey over torqued the housing.
Also just switched to Valvoline Restore & Protect. I use 0W-20 like the book says. I also do not agree with the WOT runs. Just why do it??
My GF's JK has had the same treatment and it's around 90K. (she did need a thermostat a little while back).
G.
Stetson
Salt Lake City
2019 JL Sahara, 2023 392 Rubicon, 2020 GMC 3500 Denali
Project Manager
Perform regular maintenance and have fun with it. Should last you a long long time!
Riptide_JLU
Shawn
Norcal
2021 Jeep Wrangler JLU Sport S 3.6L Auto
Data Analyst
You are doing all the right things to try and mitigate things. I would say use a quality synthetic oil. Change it up to 5-30w during non freezing conditions. Everyone has their favorite, mine is AMSOIL and am at 94k with no issues/leaks.
OminousSkitter
The Ether
Trek Bicycle
How many miles are already on it? Know its maintenance history?
The only thing I'd add is a theory behind the blown head gaskets is the bolts are under-torqued from the factory. You might want to check those.
ajbarbier
AJ
How would you go about that? Remove the intake plenum?
33,000 miles. Carfax maintenance history showed oil changes every 3-6k. Looked pretty good. Suffered from the galvanizing bs on the doors.
OminousSkitter
The Ether
Trek Bicycle
Honestly, it's just something I've thought about but haven't looked into. Looking online, it doesn't look like it's a simple "check the torque values" because it's a torque + angle for the final step [Page 9]. There are some other guys here that are way more qualified to answer this than I, and it might not be a practical preventative thing to do.
Edit: I don't have any tech/service manuals, so I can't verify the procedure there—just that linked NHTSA bulletin.
bmpcamry09
New Athens, IL
2025 JLU Sport S 3.6 8AT
-5W30 full syn oil changes every 5,000 miles max
-Spill and fill trans, t-case, and diffs every 30k
-Drive it hard, these engines gunk up if they don’t get run hard
-Run 89 octane minimum, these pull timing and ping and knock on 87 especially in hot weather
-Consider getting a tune to have VVL and cam timing manipulated, the high lift function of VVL is not used for power and it is a very harsh engagement on the cam shaft and I have reason to believe it contributes to cam lobe failure on these newer PUG units.
James Westfall
Eastern PA
A blue one
Long time listener, first time caller.
The only way to make it "bulletproof" is to redesign the valvetrain oiling system. That's the thing about the 3.6 - it has only one major, chronic issue...but it's not something that's preventable by using the "right" oil grade, or changing the oil sooner, or using premium fuel...etc. It's a design flaw and can't be easily fixed.
