Am I really this weak?! WTF
Punknhed
Virginia
2023 Punkin Rubi XR
milwaukee for the win as others have said. i have the bigass 1/2 inch drive. havent found anything yet it wont loosen. now getting its bigass into certain places......
PuddleJumper
Cortlund
NOVA
22' JTR, 23'JTM, 22' MCS
No, fuck that, I know I’m not this weak. I’ve been to the gym.
I first started trying to install RC rear LCA skids. I got the shock bolt off, but could not get the control arm bolt off, no matter what I did. I tried everything, from every position, every angle, upside down, got good leverage, but could not get it off!!
Ok, I give up on that. I also have an engine oil/tranny skid to install. Let’s try the motor mounts. Same thing, no matter what I tried they would not come off!!!
So now, here I am broken and defeated, with my brand new tools from Home Depot and no skids anywhere on the Jeep. How the hell do you all get these damn bolts off?
And now my triceps are sore.
Edit: also just found a cut on my finger.
Idk man. i got it off with a 20in breaker bar. I was smokin a Marlboro red. Maybe thats the trick.
Riverjeep
Va
25 Rubicon Unlimited, F-150
Yes, actually you are! 😂
Valpo Jeep
Doug
Valparaiso IN
1/2 inch drive 18 inch long Autozone breaker bar with a 3 foot cheater pipe on it will handle 150 ft-lbs and an extra 180* turn for Audi axle bolts that you need a 3/4 inch allen head. I set the 150 ft-lbs with my torque wrench and then turned it up to 250 to see if I could get the full 1/2 turn but I made it about 30* when the 250 clicked.
Just don't slip or you will eff yourself up.
I have a 1/2 drive Ingersol Rand air impact to do a lot of things around the garage but even that Audi bolt was too much for it. Impacts will do a lot of things but sometimes you just need leverage.
Valpo Jeep
Doug
Valparaiso IN
I have 1/2 Milwaukee Impact gun that is rated at 1400 Ft-lbs of torque. I have found that the nut comes off or it breaks the bolt.
I borrowed one of those once doing shocks on the Audi. Would not budge the shock bolt. That bolt was spec'd at 110 ft lbs + 180* if I remember. Impact should have buzzed it out like butter but a steel bolt in an aluminum part with 10+ years and 200,000 miles in salt country locked that bastard up tight. I snapped the passenger side bolt with my breaker and it took heat and beat for the driver side to come out
258_T18A
2024 Rubicon 392, 1979 CJ7
Lol, I tried pulling, pushing, kicking and screaming.
Never kick. This always leads to the bolt breaking, the tool breaking, or the tool going flying off and breaking something else in my experience. I'll use my foot on a lug wrench to break lug nuts free if I don't have an impact with me, but always use my weight combined with a slow controlled leg extension.
TrailMax
Max
Arkansas
2023 Wrangler High Altitude 4xe
That’s all I think about anytime I tighten or loosen anything lol.
And then how long does it take you to remember that this particular bolt has left-handed threads? ;)
Rogersocal
Roger
2020 Rubicon Recon 2.0 turbo, 2018 Ram 2500 6.7 TD
That milwaukee impact is a BEAST.... love that thing... why struggle when that does it with ease...
DarthAWM
Mick
Odessa, TX
2021 JT Rubicon
Oilfield Dispatcher/Semi-Professional Adult Film Star
Jeep Wrangler JL Am I really this weak?! WTF 409bcf307c341d52c5511e3dce939e4c30fd2f5fccb27ae5_1
Aussicon
Cape Cod via Australia & N.Z
2021 JL Rubicon Unlimited
Just done mine recently too. Big Dewalt impact - off = easy!
On - not so much. Used a breaker bar with plumbing pipe. If you have a hoist, it's so much easier, but a real challenge lying underneath 'cause you just can't get the leverage.
Don't forget - most of the major suspension bolts are not designed to be re-used.
LDSSILLS
Larry
Midwest
2021 JL Rubicon 4Dooor
Use a propane torch with MAP gas. Often Jeep bolts are Locktited in, even if they are not the heat will expand the lands and grooves of the bolt and help reduce any galling less friction.
Second often if you hit the head os the bolt with a hammer a few times that will work. Same principal as heat you reduce friction by loosting galled lands and grooves.
I indeed have a Milwaukee 1/2 impact wrench, they also have one on the farm. On high it is powerful enough to snap a 1/2 in bolt so use caution. So use low to start again same principle losseng up galling caused by torque. Then hit it with a very short burst of high.
Remember its always wise to use new bolts when fastening as old torqued bolts have the lands and grooves altered, thus if you torque to recomended values chances are the fastening will loosen.
Grandpa Larry
NWJeepr
Twin Peaks
2025 Wrangler 2-door
Crank on it like you've got a pair of *****, not a pair of *****.
